Question about Dryers
Dryer will not start - Dryers
    Scholar:
  • 135 Answers
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Timer If there are open contacts in the timer, it won't operate. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) Hope this helps
Posted on Dec 10, 2009
SOURCE:
Dryer comes on but won't start any cycle. What could be causing this?
Samsung Dryer Won't Start - Model DV448AGPXAA - Repair ...
www.repairclinic.com/...Dryer/...-/Samsung-Dryer-won-t-start-DV448A...
Samsung dryer won't start? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Dryer Won't Start - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/How-To...Dryer/...---/Dryer-won-t-sta...
If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a ...
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer might not be starting. ... If it makes noise but won't start trying spinning the drum empty ten times then close door and try it. ... I changed the door switch and still gives code AU. any suggestions .... thermal fuse everything seems good except my dryer won't come on!!!.
Samsung Dryer DV431AEP - won't start cycle - Appliance Repai
Jan 10, 2016 | Samsung Dv410aew 7.4 Cuft 11-cycle Steam...
I have a power but dryer wont start after i push start button. i can hear the click sound after i push the start botton but doesnt start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Samsung DV419AGW Dryer
HI, my dryer stopped working, check belt it not broken and in place. So what can it be. Can it be the starter button?
Hello there and thanks for choosing fixya
Investigate these areas if your dryer is not starting:
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
dryer_door-switch.jpg Door Switch
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
dryer_start-switch.jpg Start Switch
A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
dryer_thermal-fuse.jpg Thermal Fuse
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
dryer_thermostat.jpg Thermostat
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
dryer_timer.jpg Timer Motor
Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly.
dryer_motor.jpg Motor
A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
Jan 23, 2011 | Dryers
Dryer wont start
If the problem you are having is that your Maytag gas dryer is not starting, these are the parts you will need to check until you find and correct the problem.
You need to make sure that the wall outlet has 120 volts presents in it, in order for the dryer to be able to start. Connect a good working hair dryer in the wall outlet, if the hair dryer works, then you know that the wall outlet is not the problem.
Most gas dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting.
The timer is the distribution center in the dryer, the timer will send the right voltage to each of the individual parts in the dryer. Most common problem with the timer, is burnt contacts.
The motor is in charge of turning the tumbler, turning the blower to circulate hot air inside of the dryer and making sure that the heating element won't come on when the dryer motor is not running. A bad or weak motor could be the reason for your Maytag gas dryer not starting.
The door switch is a safety device use to prevent the dryer motor from starting or running when the door in the dryer is open. Burnt contacts or a broken actuator on the switch could be the reason that the dryer is not starting.
The push to start switch is single pole single throw switch that is use to start the motor. Once the motor starts running the switch is no longer in the motor circuit. A bad push to start switch could be the cause of your dryer not starting.
Burnt terminals or wires on the cord could be the reason for your dryer not starting.
As you can see, if any one of these parts fails the dryer will not start.
please comment on these post by staying how helpful.
Dec 21, 2010 | Maytag MDG308DAWW Gas Dryer
After i put the clothes in the dryer and close the door, the dryer will not start when i press start. It makes a short "click" sound and then doesnt start. The timer seems to be fine and the light inside...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 25, 2010 | Kenmore 92822 / 92824 / 92826 Gas Dryer
Start switch hums, does not start.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 01, 2010 | GE DWSR405EBWW Electric Dryer
The dryer will not start but the timer is working
May 21, 2010 | Whirlpool LER4634J Electric Dryer
My crosley dryer will not start when pushed, the timer starts, but no power to start dryer
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 11, 2009 | Crosley CDE6000 Electric Dryer
GE dryer must hold start button to keep dryer running
heatman101
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
GE dryer has trouble starting.
heatman101
Jan 20, 2009 | GE DBL333EA Electric Dryer
Dryers Logo
118 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
