Question about Whirlpool WFC7500VW Washer
What does error f23 mean on whirlpool wfc7500vw ? is there a home repair that can fix it?
F23 is a pressure switch error.
Posted on Mar 28, 2010
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
I have a code f25 what dos this mean
DRIVE MOTOR TACHOMETER
ERROR
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
How to fix:
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
http://www.appliancehelponline.com/whirlpool.html
Sep 01, 2014 | Whirlpool WFC7500VW 24" Front Load Washer...
Error code F-05
The error translates as "NTC faulty. Check thermostat and associated wiring." What it actually means it your water heater has almost certainly failed.
Jul 12, 2014 | Whirlpool WFC7500VW Washer
F23
PRESSURE SWTICH ERROR
The wash level and level heater safety are switched on at the same time F23
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to pressure switch and Central Control Unit (CCU).
3. Check connections of the CCU board within the housing.
4. Check the pressure switch for worn or failed conditions .
cheers
Jul 18, 2017 | Whirlpool WFC7500VW Washer
Whirlpool AWOD6727 washing machine displaying error code "F23". Help please?!?!
Could be a slow drain time issue. Excess wear makes it drain slow.
Mar 17, 2017 | Whirlpool Washing Machines
Need help with whirlpool wfc7500vw1 got code A-09
It is a fill time error, usually caused by a blocked inlet filter or a defective inlet solenoid.
Mar 11, 2012 | Whirlpool WFC7500VW Washer
Code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Sep 09, 2009 | Washing Machines
F-23 error code
HOW TO FIX WHIRLPOOL WASHER F23 ERROR CODE What does F23 mean on whirlpool washer? It means there is a heater failure. If the water temperature in the washer fails to reach 86 degrees or higher then the washer will give the F23 error code. To fix the whirlpool washer f23 error follow the steps listed below.
Note: Some models do not have a heater as shown below, some models just have a temperature sensor. If your model does not have a heater just skip to checking the temperature sensor.
  1. First unplug the washer.
  2. Check the wiring to the heating element make sure its not burned, broken or corroded.
  3. Check the heating element for continuity of course if it does not have continuity then replace the element.
  4. Check the water temperature sensor wiring for corrosion or breaks.
  5. Remove the wiring harness from the temperature sensor and measure the resistance of the sensor. Refer to the chart below and if its out of range replace the sensor.
see link below for details and where to buy the part which is under $80 and fairly easy to replace
How To Fix Whirlpool Washer F23 Error Code Appliance Repair Guides
Jan 02, 2018 | Washing Machines
Error Code
I don't have a manual on the newest dryer like you have, but one of the models just older than yours has a F23 code that indicates a shorted thermistor.( temp sensor )
Since it is new you need to call for service. They will usually look up the code and tell you if it is anything you need to check but most likely you will need a repairman to repair it in warranty.
Post back if you have any questions.
Nov 08, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool WFC7500VW Washer Logo
2,443 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
