Question about Philips 50P8341 50" Rear Projection Television
Whites are glowing - Philips 50P8341 50" Rear Projection Television
  • Philips Master
  • 8,457 Answers
Ur picture tube require coolant replacement.This website have the coolant.Tv repair World.com.
Posted on Dec 10, 2009
SOURCE:
On the hampton bay remote control fan and light module, i do not have wiring diagram. from my ceiling box, i have a red, a black, a white, and a bare copper wire. I think it is because the light switch has...
Unfortunately, Mark it's really not as simple as it sounds, to connect the wires properly. Because of that third red traveler wire for the 3-way switch. Actually, ceiling fans don't work well, when a 3-way switch is involved, because it was designed only for lighting convenience. When the fan is turned on, the other ceiling lights will start to glow, whether they are ON or not..
You would be much better served if you can locate another line to come off of and wire to that. Of course,y you won't have the convenience of a wall switch to operate it. But, that's what the pull chains on the fan are for.
Hope this helped you and thanks for choosing FixYa.
Sep 04, 2011 | Heating & Cooling
In changing the glow plug I pulled the white lead and detached the terminal. the oven is an old Tappen built in. Where does the terminal connect?
unsure what you mean here, the wires for glow coil are all underneath, some replacement glow coils dont come with the white connecter, just cut the white adapter off the wires on the range and marret the wires from the new glow coil on to the 2 wires from range, no right or wrong wiring! make sure poer is off breaker or unit unplugged!!!!
Feb 06, 2010 | Tappan Kitchen Ranges
The broiler works but the bake option doesn't work, the oven doesn't get hot, any suggestions?
Check the bake ignitor (glow bar attached to the burner). If it does not glow at all, but the voltage is supplied to it - replace. If it does glow, but draws current less than 3A - replace.
Oct 14, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
GORT007 is an id
Actualy, your correct. Just because it glows does not mean it will allow the valve to open. There is also a differance between flat and round. I would have to look it up but one has to have, I want to say 3.2 ohms and the other 2.8. I cant remember which one is which. When they are correct they do glow white. But just because they are glowing means nothing.
Oct 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
White halo fuzzes the picture on TV
Had the same problem with white glows. Followed the directions in this link and the white glows and color brilliance was fixed.
http://www.avsforum.com/avs-vb/showthread.php?t=1148792
Apr 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Lately, all "white" objects, text, spaceships, etc. have "glows"
Do you also have a glow around the projected image, try projecting on a white wall without any borders. The cause for this is dirt inside the lens elements diffusing the light.
Oct 22, 2007 | InFocus ScreenPlay 4805 Multimedia...
Extreme White Glowing
Your CRT fluid needs to be replaced. Goto www.TvRepairKits.com and order their fluid kit.
Sep 28, 2007 | Philips 60PP9363 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
