Question about Dell Dimension 3000 PC Desktop
Have driver errors on my pc - Dell Dimension 3000 PC Desktop
    Sniper:
  • 65 Answers
1.if you can connect to the internet try going to www.update.microsoft.com and use a custom windows update for hardware.
2. go to the computer manufacturers website and attempt to download from there by pluging in model number. if it is a dell you'll want to use your service tag.
3.if this does not work go to my my computer:manage:device manager: (click on the device in question) go to properties:then details. under this tab you will have a code for vendor and device. shown as ven " " and dev " " go to pcidatabase.com and plug in this information. it should give you the name of the manufacturer and the name of the device. you can then go directly to that manufacturers website and download the drivers.
4. if you do not have an internet connection try steps 2 or 3 and save drivers to a flash drive from a system that does have a connection.
5. if drivers do not fix the problem then you may have damaged hardware.
hope this helps.
Posted on Dec 10, 2009
How Do I Fix Error Code 43 in Windows 7?
This is probably one of the most frustrating and "generic" error codes reported by Windows. When I say "generic", I'm referring to the fact that Windows is basically telling you that a hardware device on your PC is well... not working. (Gee, Thanks!)
Error code 43 is reported anytime Windows does not recognize a device - whether it be a USB port, Hard drive, video card or any other piece of hardware connected to your computer.
You will usually see an error message like this:
"Error Code 43: Windows has stopped this device because it has reported problems"
And if you look at the hardware under Windows device manager, you will see something like this:
NOTE: The hardware device above is only an example. It could be any device on your computer that is reporting error 43.
What Causes Error 43? 95% of the time, error code 43 means that a device driver is either missing, corrupt, outdated (so Windows problems communicating properly with the hardware), or the hardware is faulty and needs to be replaced.
Device drivers can become damaged or corrupt over time, and most users will eventually experience a driver error. Installing and removing software and hardware can cause conflicts in the registry and can alter driver communication.
Sometimes you can bypass the error temporarily such as removing the device from the motherboard and reseating it, removing the power cord from the power supply and restarting your computer after a few minutes, etc. However, theses are temporary and will not fix the actual problem.
Solution For Fixing Error Code 43 Messages The first thing of course is to make sure your device driver is up to date. I have provided two ways to accomplish this below:
Option #1: Update your drivers automatically (the easy way)
If your not that technical and don't want to hassle with trying to locate the correct device drivers from your PC's manufacturer and then go through the process of uninstalling and re-installing your drivers manually, then you should run a free scan with a recommended driver tool.
This software will match and download the correct drivers you need. It's safe and saves a lot of time keeping your PC updated.
Option #2: Update your drivers manually (the technical way)
If you consider yourself pretty technical and feel confident making changes to your system, then follow the steps below:
Step #1 - Uninstall the current driver:
First, you need to uninstall the current driver...
  • Click "Start > Run" and type "sysdm.cpl" in the text box and press ENTER
  • Open the "Hardware" tab on the System Properties dialog box, then click on "Device Manager"
  • Double click "Device Type", then click on the hardware device that is reporting Error 43
  • Next, go to the "Driver" tab and click "Uninstall" to uninstall the device driver completely
Step #2 - Locate the correct driver:
After you have uninstalled the driver, visit the manufacturers website and locate the newest driver for your device. You can usually find the latest driver under the technical support or driver section of the company's website.
Step #3 - Download the driver:
Download the driver and save it to your computer. It will most likely be compressed in a .ZIP file, or an executable file (.EXE).
Step #4 - Install the new driver on your PC:
Extract the .ZIP file or double-click the .EXE and install the driver.
Step #5 - Reboot your PC:
If you uninstalled the old driver and installed the correct new driver, it should fix the communication problem between Windows and your hardware device, eliminating the error 43 message. If not, you might want to install the faulty device on another PC and see if it works correctly.
If you continue to experience problems then most likely the device itself is damaged and needs to be replaced.
Good luck.
Semper Fi,
Z
Feb 19, 2018 | Computers & Internet
Sound is not working
The below should solve the problem
1. Downloaded the latest driver from support.dell.com from the Downloads and Drivers section.2. Uninstall the Driver from either the Control Panel (Sound Max) or by going to the Device Manager and rightclicking the driver and Uninstall.3. Restart the Computer.4. Install the Driver downloaded.
If the above does not work
a) Faulty hardware is not allowing driver to be installed and sound to come out.b) Corruption in Windows, that would require a new reformat of PC.
Jan 19, 2012 | Microsoft Windows XP Professional for PC
When i start my fifa 11 then it can't start its writting E0001,what shoul i do?
Lol just change your resolution and then change back....worked for me
Dec 10, 2010 | Computers & Internet
I found vga drivers but it not work either i installed directly from the icon or from root directory of the this model d530 cmt. how can i install vga drivers?
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout registry cleaner and then install ur recommended driver as u want to install vga driver.
Aug 31, 2010 | HP Compaq d530 CMT PC Desktop
Problem installing broadcom netxtreme gigabit NIC in windows server 2003 R2 standard, the driver doesn't load, error code 38
Determine Correct Driver Click Here
1: Uninstall any unwanted programs.... (make sure/Try to Clear your Hard Drive more than 50% as free)
2: Update virus software
3:Restart Computer IN Safe Mode
4: Run Virus Scan
5: Restart in Safe Mode
6: Uninstall Existing Driver Software From Device manager
7: Restart computer in normal mode
8: Start>Run> type %temp% and hit run.
9: Delete all files in this folder....
10:Restart Computer
11: DEFRAG
13: Restart COmp.
14:Install Driver
>Troubleshooting for Error 38
The error message for this error appears as: "Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory."
This error occurs when a previously loaded driver is preventing the new driver from loading. To fix this error follow these instructions.
  • Reboot Your PC
  • Open the Device Manager and in the device Properties box, select the General tab.
  • Properties Uninstall(Right Click Mouse) / Disable(In Property)
  • Restart PC
  • reinstall /enable
  • Once you have followed the instructions throughly, reboot your PC
Hope this make you Better Conclusion....Thanks for Using FixYa.....
Apr 21, 2010 | Computers & Internet
While installing audio drivers iam getting error
If you are running Vista it will not detect you need to got the PC site and and download all the drivers for your PC.
Dec 29, 2009 | Computers & Internet
Good evening, was trying to install the pc suite for my lg arena km900, but an error code came up at the end, causing the installation to stop. Error code was 0x000FFF. Any suggestions? Initially tried...
whenever you are installing any Plug and play device its always advisable to never connect it before installing the drivers. First uninstall whatever you have already installed. Remember your phone should not be connected to the pc. restart you machine install the drivers connect your phone only if driver asks to do so or else just re-start your pc after installation. connect your mobile let it install its drivers automatically. and you are ready to use your LG.
Jul 31, 2009 | LG KM900 Arena Cell Phone
PC Cam Driver install - blue screen driver error after restart
Try to update your outdated or corrupted drivers with a <a href="http://www.bestdriverupdater.net/">driver update tool</a>.
Apr 27, 2009 | iClick Intova IC800 Digital Camera
Blue screen error
Search the stop error at microsoft.com. It will give more information about the error.
Mar 12, 2009 | E-Machines T2200 PC Desktop
Dell Dimension 3000 PC Desktop Logo
42 people viewed this question
Alun Cox
