Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
What is the proper temperature setting for the freezer?
  • 4,070 Answers
0 TO 10 degrees F.
Posted on Dec 10, 2009
Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Apr 30, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
Frigidaire ffu1767fwo (power spike) does not turn on can it be fixed
Hello tom97420 - Was the freezer unplugged during the power outage? It is best to be unplug unit and wait for the power to come back on, turn control to off, plug the unit in and reset control to factory suggested setting. Do not open freezer door unnecessarily if freezer is off for several hours. Make sure the freezer plug is tightly pushed into electrical outlet and not plugged into a GFI. Is the temperature control in the OFF position? Set temperature controls to proper setting suggested by owners guide or set to the halfway point and adjust it up or down as needed. If any suggestions are ineffective, contact a professional to move forward accurately. From what you have described the power loss could have possibly caused a communication problem with the control board, temperature control or wiring harness.
Oct 24, 2012 | Frigidaire 16.7 cu. ft. / 473 liter...
Tempt setting
Hi - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Oct 19, 2012 | Frigidaire 16.7 cu. ft. / 473 liter...
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Frigidaire freezer has ice accumulating and not freezing properly. Ice cream will not freeze.
Try turning the temperature control to off, unplug the electrical power cord from the power outlet, defrost the appliance, clean the condenser, plug the power cord into an electrical outlet, set the temperature control to a low setting, lay a thermometer in the freezer for a few hours and see what happens to the temperature in the machine.
Check the integrity of the seal of the door gasket by seeing how the door seal will hold a slip of paper in various locations along the freezer door gasket. A loose hold on the slip of paper shows an area where hot moist air can get into the freezer and cause ice build up.
Aug 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
What is the temperature for the numeric settings? Thank you!
do not rely on the "settings" for the freezer,they are a guide ONLY.use a proper thermometer to get it to minus 18C.
Oct 04, 2010 | Frigidaire 12 cu. ft. / 340 liter Upright...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
249 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
