Question about ViewSonic VA721 17" LCD Monitor
A pop up window appears and says no signal analog
    Sniper:
  • 65 Answers
This is most likely a pc hardware issue and not a problem with the monitor itself.
1. check cables and power switches.
2. remove devices from power strip and then plug them back in one by one.
3. try alternating memory sticks to diagnose if one may be bad.
4. remove pci dial up modem card.
5. if you have an agb, pci, or pci-e video card remove it and plug monitor onto the onboard video if the option is present. if not test with a known good video card.
6. if possible test pc power supply with known good power supply as it may have gone bad.
any damaged piece of hardware could potentially cause a system to not post or display to a monitor check these first as they may be the most likely culprits.
hope this is helpful.
Posted on Dec 10, 2009
Media center won't connect to analog TV signal
If my memory serves me correctly, you need vista pro. home just isn't powerful enough and not made for it.
Jun 01, 2009 | Microsoft Windows Vista Home Premium with...
I have a minidisc model mds e10
it seems your MD unit is expecting a digital signal on the digital input causing this message to appear.
You need to connect a signal source to the digital input
or
connect an analog signal to an analog input and select the analog input as signal source.
In both cases the DIN UNLOCK message will then disappear.
Cheers
May 14, 2009 | Sony MDS-E10 Mini Disc Player
No Signal on Lubbock, TX channel 11.1 but receive all others
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna.
biigg53566
Feb 19, 2009 | Insignia Digital-to-Analog Converter for...
Air analog 3 message keeps popping up what does that mean?
I bought the 32 inch LCD tv. I contacted Sharp. Here is there response.
Thank you for contacting Sharp Electronics Corporation.
The display will populate on screen any time there is a change to the incoming signal (mono to stereo audio, weak/fluctuating signal strength). Unfortunately there is no way to deactivate the on screen display. If you are able, try using an alternate connection (composite video and analog audio; yellow, red and white cables) from your source device (cable/sat box, if using) to the unit. This will prevent this issue from occurring by providing a more consistent signal. Let me know if you have any other questions!
Jan 02, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VA721 17" LCD Monitor Logo
227 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
