Question about Gaggia MDF Electric Burr Grinder
How can I clean my Gaggia burr coffee grinder?
How can I clean my Gaggia Household Coffee Grinder?
  • 19 Answers
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Posted on Feb 12, 2010
  • 4 Answers
Easiest way without disassembling the burrs themselves:
1) remove the coffee bean hop by peeling the 2 rubber grommet
2) unscrew 2 small bolts underneath
3) the burr becomes partly visible
4) scrap the coffee/oil/gunk
5) use a handheld rocket air blaster, like those used in camera lenses, to blast into the burr and hard to reach places
6) remove bottom plate (4 screws), rotate the white round plate in the bottom to move the burr grinds. Repeater step 4) & 5)
Posted on Feb 16, 2016
    Problem Solver:
  • 5 Answers
I have never used anything harder than a nylon brush on my grinders and usually use a cheap acid brush available at your hardware store.
Some people do use rice, but I don't know if that might gum up a machine. Should you use converted rice (already steamed)?, brown, ? white? .
On a decent grinder, Gaggia MDF and up, I would use Grindz by Urnex.
Panko will have odd oils on it and perhaps unususal flavorings as well.
Posted on May 07, 2014
I just disassembled and cleaned my Gaggia coffee grinder. When I turned it on to calibrate the burr plates it made a short grinding sound then stopped and now won't turn on
Take it apart again and check all the connections and switches, security shut-offs, and THE THERMAL SWITCH. A very small and cheap electronic device that takes and overload and will shut your system down, whatever it is. Very easy and quick to replace.
Nov 25, 2014 | Gaggia MDF Electric Burr Grinder
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
How do I reset the burr grinders correctly after taking the machine apart for cleaning?
WERY SIMPLE:
  • turn on the grinder
  • while it runs you screw upper holder until you hear metal sound of burrs contact
  • you go back than for 3 points
  • grind 7 grams and test it.
or>>> mark it with marker before disassembling and count the revolutions.
Mar 06, 2011 | Gaggia MM Electric Burr Grinder
How do you change the grind on a gaggia coffee grinder?
if it is everything in order you change the grind buy rolling the plastic container of coffee beans(container commands to upper burr holder. If it doesn't go easy than disassemble container and unscrew the upper burr holder, carefully when it comes out, you have some pins and springs from below. do not loose or displace them.
Jan 03, 2011 | Gaggia MDF Electric Burr Grinder
Hi i have on the screen grinder blocked, i have clean it out and checked the grinder motor its ok. Switch it back on gone to make a drink but come back on the screen grinder blocked. Anybody got any idear...
When you said cleaned it out did you remove the grinder burr gears,vacum out the coffee shute and the coffee dump solenoid?
I do this then put it back together,set the grind on 7 and normally all is good.
Nov 19, 2009 | Gaggia Titanium Espresso Machine
SUP021 YR keeps getting clogged
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Sep 04, 2009 | Starbucks Saeco Italia Digital Barista...
Grinder is slipping.
  1. take out bean container
  2. disassemble 3 philips screws and take plastic out
  3. rotate the knob to try to get out the upper holder of burr. if it does not rotate than disasemble the knob and the gears(plastic big one is attached to upper holder of grinder, the other is together with knob.
  4. tru to rotate it manualy, with help of extra srews puted in gear holder holes.
  5. when you get it out, carefuly clean it, look for metal parts and stones(wich sometime comes with coffee)
  1. turn on the grinder and attach gently one marker to lower burr during spining. after you stop grinder, look if it is perfect circle marked in burr. if it is not than marked side is higher. you should consider getting it ok by putting adhesive paper under lower burr and check it again.
good luck and carefuly.
Aug 02, 2008 | Gaggia MDF Coffee Grinder
Gaggia Syncrony does not get past the grind cycle
Water has probably been spilt in the beans area. The grinder needs cleaning out along with the chute
Feb 24, 2008 | Gaggia Syncrony Compact Coffee...
It could well be gummed up with years of coffee bean residue
Very simple to take apart. There are two screws holding the cannister. They are hidden under 5mm round rubber covers that you have to pry off. Then remove the two screws holding the plastic cover. Mark the position of the numbered dial relative to the brass burr assembly then remove it. Once exposed, you should be able to figure out why it is locked. Scrape away as much gunk as you can.
Aug 18, 2007 | Gaggia MDF Electric Burr Grinder
Gaggia MDF Electric Burr Grinder Logo
977 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
