Question about Dimplex CS3311 Compact Heater
What is the name of the part that receive the signal from the thermostat?
    Problem Solver:
  • 17 Answers
It may be a silnoid switch
Posted on Dec 10, 2009
My ice maker has ice in the tray but not dropping in Ben,it is a kfil27cxmso there is a lite that sends a beam across ben ,how do I check to see if the bulb is blown or working, gk
Hello George;
My name is Peter. I am a retired field service technician.
I live in Baltimore, Maryland, USA.
All ice makers work in the same way.
Your fill cycle is working fine. You have a thermostat in your ice maker which tells your ice maker control module (Computer) that the ice cubes are frozen and ready for harvest. Then, then control module tells the cube tray heater to turn on for so many seconds, followed by the control module to activate the harvesting motor.
So, your ice maker either has a bad thermostat, heater or motor.
The beam across your freezer section is a safety device. On the right hand side is the transmitter. On the left hand side is the receiver with a plastic flapper. When you close the door the flapper closes and completes the signal to discharge ice. When you open the door the flapper pops out blocking the signal.
Dec 02, 2014 | Refrigerators
I only have B, O, G, Y, W, R, & RC on my honeywell thermostat. What terminal on a honeywell thermostat is the L terminal?
The L terminal is not a commonly used terminal. On some heat pump systems, the L terminal can be used so that the thermostat can "monitor" the heat pump. Basically, sending or receiving the low voltage signal. It is not a required terminal.
Oct 24, 2013 | Heating & Cooling
Huawei mobile AIRTEL
You can go to the settings then check the user name and password. If the user name and password is not correct then you will not get the signal or the data card that you are using over there the network signal strength is not good.
Oct 15, 2013 | Dell Computers & Internet
Can a samsung blue ray player BD-E6300 receiver signal from skydigi box?
For more details type in this site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site name, either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more.
Jun 06, 2012 | Samsung BD-P1400 Blu-Ray Player
2000 Toyota 4Runner Keyless Entry not working. FOB is transmitting, but what about the receiver?
Remote Entry Receiver is inside the back lift-door panel. Open the panel and check the receiver antenna (a wire hanging out from the receiver). Try to stretch out the antenna as far from the receiver as you can so the receiver gets the maximum range for signal receiving. Since you said you had the FOB tested and it worked fine, your signal transmission side is OK. The issue is at your receiver side. Good luck.
Jan 21, 2012 | 2000 Toyota 4Runner
My name is hector, early this morning i accidently unplugged my recieve out of the power outlet, and now it wont get a signal... also there is no blue led light showing like it normally would, can you...
Hi Hector, my name is Cheri Torres with DISH Network Customer Service. When you say your receiver is not getting signal do you mean it has a DISH Network error message on it such as 015 or 002 or does the screen actually say "no signal". You are going to want to check all cabling, make sure that all of them are connected and screwed in tightly on the back of the receiver leading to the TV and to the wall. Once you have checked all the cabling you are going to want to perform a hard reset by unplugging the receiver for ten seconds from the wall outlet. If both options do not work for you I would like you to contact me so that I can assist you further with this issue. You can email me at Cheri.Torres@Dishnetwork.com with your account information and I will be happy to help. Thanks and have a great day!
Feb 17, 2011 | DISH Network 322 DTV Receiver
What is the solution to bad signals from satellite cable during bad weather
Hello, my name is Nick Franta with DISH Network Customer Support.
Weather issues can happen with satellite signal. If you are experiencing heavy snowfall, wiping off the DISH of any excess snow will help the signal.
If you have any further questions let us know!
Dec 16, 2010 | DISH Network 322 DTV Receiver
I have a honeywell cm927 control unit, and the red light on the receiver keeps flashing. i can manually turn the boiler on and off at the HC6ONG receiver. i've tried the faqs in the manual but to no joy....
The red flashing light means that there is an issues with the RF comms between control unit and receiver. You can reset by switching the boiler off and back on and then re-sending the temperature signal. You need to check batteries in you thermostat and also the position as the signal could be interfered with or it may be too far away from the receiver.
Sep 25, 2010 | Honeywell Programmable Thermostat Heater
We have an old dish network dish and LNB with a new dishnetwork receiver. When we can get the signal up to 5, the screen goes blank and we cannot lock the signal in. Diagnostics state there is no...
Hi mfpayton with the install of the brand new receiver wealways want to make sure all connections are tight. And after all connectionsare hand tight we will need to run the Check Switch Test. It will provide thestrongest signal to your home and you will see the signal move up into the 65percent range. If after the Check Switch Test it still is a low signal we mayneed to check the connections from the Dish and LNB that is an issue we wouldneed to come out on. I will leave the link to show you how to do the CST.http://www.dishnetwork.com/SupportSection/complete-sig-loss
Mike Houston of DISH Network Executive Office
May 02, 2010 | DISH Network 322 DTV Receiver
Dimplex CS3311 Compact Heater Logo
120 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Naveen Sistla
Naveen Sistla
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
