Question about RCA D52W19 52" Rear Projection Television
Arcing in lower back left corner
While watching TV quit and I noticed arcing inside the back panel - lower left when facing back of TV. I took access panel off and it's coming from a piece that is approx 1.5 to 2" wide and approx 3"tall. It has hwt looks like two adjustment screws on it. Top one has focus and lower one has screen. What can I do and how much will it cost?
  • RCA Master
  • 5,138 Answers
Replace flyback transformer cost verys from 21.00 - 71.00
Posted on Jan 26, 2008
6ya staff
SOURCE:
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
microwaveglasstrays.com/shop/articles-arcing.html
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
www.repairfaq.org/REPAIR/F_micfaq3.html
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
MICROWAVE OVEN ARCING ' MICROWAVE OVENS
Dec 15, 2015 | Microwave Ovens
Kitchen aid microwave Kcms185j is arcing on the inside ceiling when popping popcorn, but normal when frying bacon?
It may be the oil in the popcorn---do you own one of the covers that go inside to cover so food does not splatter?
Dec 22, 2012 | KitchenAid KCMS185J Microwave Oven
While cooking in our Whirlpool GH5184 microwave an arcing appeared near the L/H lower corner of the unit. After shutting it off we observed a black arc mark on the inside of the door and a small hole from...
This is caused by either carbon arcing from carbonated food deposits or metal dish or bowl being used inside the machine causing a track. Even a recycled paper towel can cause it as the towels have metal traces in them.
Dec 13, 2010 | Whirlpool GH5184XPQ Microwave Oven
A shorting noise is coming from inside the tv box - this happens when i switch on the tv but later , after 5 minutes or so stops - the noise , in bursts, asif two wires are touching.
Hello
There is a high tension arcing takes place inside your tv. It may be related to Line Output Transformer [LOT], and neighbouring parts. You can locate this by placing the tv in an absolute dark room, switch it on, and notice its inside through the back ventillations. you may see bluish arcing takes place, and an ozone smell will come too. Never switch on the tv till this fult is retified. Some other parts alo may get damaged.
Contact a sevice personal and get it repaired as soon as possible.
Oct 19, 2010 | Sansui 32" TV
Runs like ****, backfires and chugs, no power
Several possibles: Plug wires arcing (run engine in a very dark area and open hood to see is there is arcing) Bad coil (same test look for arcing sometimes you can hear spark jumping) Distributor cap arcing inside or outside ( remove cap and inspect for carbon tracks inside cap). Module inside distributor bad (not too expensive to replace). Lean toward wires or coil.
Dec 03, 2009 | 1989 Chevrolet S-10 Blazer
Tv went off and won't come back on.
the arcing sound is some kind of high voltage leak, which will shut down the tv. pull the speaker grill off and the access board, look at the 3 picture tubes, turn the set on you will see where the leak is, it's usually the high voltage splitter, which has a high voltage wire going into it and 3 high voltage wires coming out going to the picture tubes, if it arcs from the splitter you need to change it, if it arcs from one of the picture tube wires you need to pull the tube out and fix the high voltage leak, and possibly a cooling fluid leak caused it, not an easy reapir, you probably need a repairman.
Sep 08, 2009 | RCA P52926 52" Rear Projection Television
Blurry picture with arcing
this is the the fly back transformer ,replace it or if you are not a repair man ,please contact the nearest repair shop.(risk of shock hazard -high voltage!!!).
Jul 31, 2008 | Toshiba 36A40 36" TV
D52W20 circuit board
The center circuit board is the green CRT drive circuit. that board could be bad or the green CRT could be faulty. I have access to both those parts for your model
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Arcing inside no picture
Most times arcing like this is from the Horiz. output transformer (flyback). The insulation has a break down and up to 30 KV will find the nearest path to ground. This would require a tech. to repair the unit. This repair will most likely cost around 250.00.
May 09, 2007 | Sony KP-51WS510 51" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
