Car problems i have a renault extra van 1994 diesel and i need to know where the solenoids are and the alternators are
  • 92 Answers
Do you have a copy of the manual ?
Posted on Feb 07, 2008
Where is the fuel cut off switch on a renault.kangoo van 1.5 diesel
A lot of Renaults have a red connector in the engine bay with a 3 prong solenoid. It is hard to determine where yours is considering the lack of year. Renaults do have a cut off solenoid as do many vehicles.
Sep 02, 2016 | Renault Kangoo Cars & Trucks
I got a OBD car fault code po745.,on my Renault methane senic 2003., 106k ml.,what does it means?
P0745 - Pressure Control Solenoid Malfunction Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty line pressure solenoid valve
- Line pressure solenoid valve harness is open or shorted
- Line pressure solenoid valve circuit poor electrical connection Help with this
Tech notes
When the a transmission solenoid is malfunction, in most cases the problem is not the electrical part of the solenoid; the problem is foreign material obstructing the mechanical function of the solenoid or the flow of the fluid through the transmission valve body. If the transmission fluid is very dirty, it is recommend changing the transmission fluid and if possible removing the transmission pan for further diagnosis. Excessive debris or metal particles on the transmission pan could be an indication that there is a transmission mechanical failure and that the transmission will need to be rebuilt or replaced.
Help with this
When is the code detected?
The P0745 is detected when TCM detects an improper voltage drop when it tries to operate the solenoid valve.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Transmission shift shock
P0745 Description
The line pressure solenoid valve regulates the oil pump discharge pressure to suit the driving condition in response to a signal sent from the Transmission Control Module (TCM).
TURBO BOOST PRESSURE SOLENOID VALVE DIESEL VAUXHALL MOVANO VIVARO RENAULT...
Apr 11, 2015 | Renault Megane Cars & Trucks
Diesel engine problems
Is it a turbo diesel? It sounds like the turbo is shot. Black smoke and runs like **** a pretty sure signs.
Jul 04, 2012 | Renault Cars & Trucks
2001 citroen belingo diesel van will not start,can prime diesel to filter and on to injecter pump thats where it appears to stop and will not reach the injectors
Depends on the mileage of this car, it can be one of the elctric valves on the injector pump or the pump itself. You need to check the solenoid valve as well (it is an electro-magnetic valve that opens or closes, check the mini-filters underneath these valves. When this does not help than you need to get your pump either fixed or replaced, last function is very costly.
Apr 21, 2010 | 2000 Renault 181
I have a renault kangoo van, an brake pedal is rock solid which effects braking does anyone know the known causes
hi from uk this sounds like you have no servo assistance with brakes? if your engine is diesel? then the vacuum pump is not providing assistance there are different methods of haw vac pump is driven? some are driven off rear of alternator/ off the rear of camshaft ? if petrol engine ? the vac is a pipe from inlet manifold connected to servo unit this pipe has also a none return valve fitted may i suggest whether diesel or petrol engine you check the hoses from pump to the servo ? also if alternator driven pump? check fanbelt? if ok then to check if pump is fault? pull out the hose /pipe from the grommet entry point on servo unit and with engine running ? you should feel vacuum if you put finger over the end ? no vac ?? you will have to check the drive coupling from alternator if diesel engine ? if you come back with more info after tests above ? may be able to advise further?
Mar 15, 2010 | Renault Le Car Cars & Trucks
Kangoo 1.5 diesel van wont start.
Just had exactly the same problem with my Kangoo, the bolt had come loose on the bottom crank pulley and the alternator belt came off, unfortunately, as I have found out, this allows the cam belt pulley to move on the shaft and the timing will have slipped and this almost certainly causes damage to valves, pistons etc. I'm just about to strip mine down to find the damage.
Not good news but hope it helps to find the problem.
Fraser.
Feb 17, 2010 | Renault R18 Cars & Trucks
Renault Kangoo Van ( Diesel ) Occassionaly the van goes rather sluggish. Can't get above 45 mph? Then everything seems okay. Any Ideas !!!
sounds like a fuel isue have you changed your fuel filter lately and have you used any gasline antifreez
Dec 30, 2009 | Renault 181 Cars & Trucks
How much oil in my van
5-6 quarts if empty.
May 31, 2009 | 1994 Ford Econoline
Diesel pump on a renault master van
EASY ENOUGH JOB JUST MAKE NOTE OF TMING MARKS
Oct 15, 2008 | 2000 Renault 181
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
