Question about Toshiba TN50X81 50" Rear Projection Television
I just hooked up a HD cable box. However, cannot get a 16:9 HD picture. It is still a 4:3. Is there a setting on the tv? Any other ideas?
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
This is a early HD set---what I call first generation--IT DOES NOT HAVE THE 16 X 9 FORMAT.
Many of the early HD sets are like this--4 x 3 or letter box type HD picture only.
Sorry to give you bad news but based on the model number it does not have 16 X 9 format.
If this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 10, 2009
Testimonial: "thanks."
My TV has 4" of blank space on the right and the left of the picture. My TV is a 4 year old Vizio. Is this an indicator of a TV dying?
Might want to check if the aspect ratio in the video setup got messed up. (Should be 16:9 or auto.) Also check that you're watching a HD channel or a HD DVD. Your cable box may have a video out setting that got reset incorrectly.
Jan 23, 2015 | Vizio Televison & Video
Samsung 40" tv Just got HD but when i put the tv into 1080 mode it alters the tv picture aspect to panaramic and wont change it will only work on the lower HD setting. Any ideas
if you go into the samsung menu and change the auto view to off then on your HD box im asuming your with sky you can press you services, 4, picture setting then ensure this is on 16:9 job DONE
cheers
Little Dish Fitter.
Sep 01, 2009 | Televison & Video
Picture is to tall. it cuts off the top of the heads
It sounds like you have the image on the perspective. If you tv is 4:3 aspect ration the video source (cable box, dvd ) must be set for a 4:3. If you have a 16:9 ratio (widescreen) the soutrce should be set to 16:9..................Nevermind, Just looked it up you this TV is 4:3.
Your TV remote will have a button to toggle/change the aspect ratios of the TV. Button could be called picture/aspect/image etc. If you have an HD cable box you need to go into the video setting and chnage the aspect ratio to match the 4:3 tv.
If you need more help, please respond with more deatils.
Jan 19, 2009 | Sanyo DS32830H 32" TV
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
16:9 Enhancement (KV-36HS510) HELP!!
There is a hidden setup on cable box.  Search manual on box.  I have the same TV with a Scientific Atlanta HD DVR.  If you turn off the cable box and hold the Guide + Info Buttons down, it will go into supported resolution setup.  My TV now goes to the appropriate resolution (480i, 720p or 1080i) what ever the channel is broadcasting.
Dec 12, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Picture selection
If you have a motorola HD box turn off the cable box...press menu on cable box front...select 4:3 override stretch and TV type 16:9
Nov 03, 2007 | LG 42PC3DC 42 in. Plasma HDTV
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Picture not to full screen
Try connecting just the cable to the TV and bypass the cable box. If you get a full screen and the "ASPECT" button on the remote gives you full operation then either you need to change the output on the cable box to 16:9 output at 1080i resolution (because it sounds like the box is putting out a 4:3 screen size)or in your customer menus on the TV, I believe there is a "AUTO ASPECT" selection? If there is and it is activated then turn hat off. Having DVR won't effect the screen size. It just means the cable box has a hard drive built in to it.
Mar 12, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Toshiba TN50X81 50" Rear Projection Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
