Question about Brother MFC 210C All-In-One InkJet Printer
Brother Printer - Keep complaining about No Ink
Brother Printer MFC 210c - Keep complaining about ''Ink Cartridge Blank'' even after installing a new cartridge, appreciate your help.
  • thajiksha Dec 10, 2009
    Now I'm getting the message No Cartridge and I'm wondering it is very much installed as expected but still complaining about No Cartridge. Please help.
    Thanks,
    Hello, My printer MFC-210C is keep complaining about Ink Empty Black... But I just replaced the ink cartridge. It is also complaining about other colors "Near Empty". Now I couldn't use the printer as its complaining about Black cartridge. Appreciate your help
    President:
  • 3,278 Answers
Hello.
From Brother support:
"The message #NO CARTRIDGE# may appear if one or more of the
cartridges are not properly installed or an ink cartridge is
defective,such as air bubbles, or empty. Verify all the cartridges are
installed correctly and they are not empty or defective by following
the steps listed below:
NOTE: Cartridges that have already been installed are no longer
vacuum-sealed; it is very important that the cartridge remains upright.
If the cartridge is removed and placed on its side, air may be
introduced into the ink supply tubes, requiring repeated cleaning
before print quality is restored.
a. Lift the top cover to the open position until it locks securely
into place.
b. Then, remove all ink cartridges by pulling the white plastic hook
toward you and pulling the cartridges up and out of the machine.
c. Because all the ink cartridges have been removed, the LCD will
prompt you to install each color cartridge.
d. Important!! Reinstall the ink cartridge(s) in the order of the LCD
is instructing you too. Press down FIRMLY on the top of the cartridge
until it is fully seated. Push the white plastic hook towards the
cartridge to verify it is fully latched over the top edge of the
cartridge.
e. Close the top cover. The LCD will ask you if you have changed the
cartridge to new. Press 1 for yes and 2 for no. Press 1 for yes for
each color. The LCD will alternately show CLEANING and PLEASE WAIT. When the Brother machine completes the cleaning cycle, the LCD returns to Standby mode.
Hope this helps.
Posted on Dec 10, 2009
  • NinaE Dec 10, 2009
    So, you followed those instructions, including removing all ink cartridges, and you still received the "No Cartridge" and other messages ??
My Brother MFC-210C All-In-One Printer is working as if it's printing, but the paper is blank! Please help!!
in the computer click the printer icon and see if there is any printing Que if there is delete all then close it then click start settings printer then make the printer your default printer then right click the default printer and click print a test page also check the cartridge ink level
Oct 26, 2011 | Brother MFC 210C All-In-One InkJet Printer
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer will not print installed new black ink now it says megan out but it is new also , will not clean do i need new printer brother 210c 5 yrs. old
Try to pull them all out then close the cover. Machine will tell you - no cartridge - install bk ink.... then the others!This may clear your problem(i hope so ) :)!
Aug 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
MFC does not recognise the new black ink cartridge.
Disconnect power supply and USB lead (leave disconnected for 10 min). Repeat this for each colour that is not working and hey presto the LCD readout will revert to normal and you will be able to print again. Happy Christmas! Hope this works for you (worked for me)
Dec 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother 210c says ink needs to be reinstalled
i have just bought new cartridges and it asks have you replaced yellow, i say yes it says no cartridge, any ideas?
Sep 07, 2008 | Brother MFC 210C All-In-One InkJet Printer
Replac ink
i got something like that too .. it was my yellow ink which was doing it ... at a point i was so fed up that i put another blue cartridge and you know what .. it works ... so it means that the brand new yellow that i bought before was not even good !!! WOW .. way to go Brother !
Jul 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Defective LC41y ink cartridge
is the ink cartridge brother approved use a genuine brother cartridge
Mar 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
Cartridge
Chances are the new cartridge is defective.
Check the expiration date on the cartridge, and even if it is not expired, I would suspect the cartrigde is bad, dried out, not allowing the ink to lower.
That is the most frequent issue with your problem
Feb 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-in-One Ink Cartridges
near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc 210c printer
Check ink cart if it is well placed into the ink cart assy. Do the cleaning procedure by pressing INK skip the arrow-button down until CLEANING is displayed. Press start mono (blue button). After cleaning cycle you are asked by machine to print a quality test sheet. Do so and follow display instructions. Do the cleaning procedure a max of three times! When there still is no BK the printhead either is clogged or dryed out. Sorry, this cant be fixed anymore.
Oct 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
179 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
