Question about Whirlpool Duet GHW9150P Front Load Washer
Getting F20. what does F20 mean when it flashes during cycle?
    Scholar:
  • 68 Answers
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
Posted on Dec 10, 2009
Hi i have a indesit washing machine and it keeps stopping during a cycle and flashing F20 do you know what might be wrong it is not draining water
Find out what the F2 0 signifies. But if it is not draining water, clearly the pump is not functioning. Find out why.
Sep 02, 2017 | Indesit Washing Machines
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer keeps flashing F20
Hi
Error F20 means Water Inlet Problem-no water or insufficient water supply.
This issue can appear due to faulty inlet valves or due to blocked inlet hoses. Also check the filter screen at inlet valve, clean them if they are dirty.
Select PAUSE/CANCEL twice to cancel the cycle. Unplug the washer or disconnect the power. Now check whether water faucets completely turned on?
Make sure that the water inlet hoses are not frozen. If above things seems to be fine then you would need to replace the water inlet/fill valve.
Hope this helps... Please post back if you need more information.
Daniel
Jan 23, 2011 | Washing Machines
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
MAYTAG 3000 SERIES JUST RECEIVED AN F20 CODE. WHAT DOES F20 MEAN? THE MECHINE RAN FOR 10 WASHING THE STARTED STOPPING ABOUT 10 MIN IN TO THE CYCLE WITH F-20 FLASHING.
need the correct model # and ser # _ _ _ 3000 _ _ _ _ this tell us age and and fault codes . now inside the machine / you will find a tec sheet with the codes . this may be quicker .. mm
Dec 02, 2009 | Dishwashers
Our Kenmore HE2 keeps giving f20 error. Water pressure is fine. No kinks in hose. Cleaned out junk in trap behind the bottom panel. Ordered new pressure switch. Works fine on clean washer cycle, but with...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first
Dec 02, 2009 | Kenmore Elite 45986 Front Load Washer
My washer is flashing F20 what does that mean stopped during cycle and flashed f20
F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
487 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
