Question about Vehicle Parts & Accessories
I need a wiring scamatic for a 2002 dodge ram 1500 with all power i have model icbn/.7071 two way starter and alarm thanks my email is dan_wolcott2003@yahoo.com
  • 41 Answers
Http://www.bulldogsecurity.com/
go to vehicle wiring diagrams
Posted on Feb 03, 2010
Can I use a 1995 dodge ram 1500 starter in a 2002 dodge ram 1500
I guess the short answer is no.
It depends on the engine and trans, but the starter for a 1995 model 5.2 is different from a 2002 model with a 4.7 engine.
Sep 16, 2015 | 1995 Dodge Ram
2005 dodge ram 1500, will not turn over. Battery is hot and tapping on starter doesn't help.
What you need to do is check to see if your getting current coming from the key switch to the starter. it's the thinnest wire that goes on the startex, that little round thing on the starter. if no current check the fuses you will see one as ( ST ) that is staring fuse. If fuse is ok then you check the starter relay and if that is ok then you might have a broken wire. to make sure the starter is working you could put the van in park and connect a jumper lead to the startex where the small wire runs to the starter and touch the next end to the B+ or 12 volts side of the battery and if the starter works then you have a broken wire.
Feb 25, 2013 | 1998 Dodge Ram 1500 4WD
Alarm wiring diagram 2008 dodge ram 1500
Check HERE for details.
Also can check this documents.audiovox
Hope this help (remember comment and rated this).
Apr 23, 2010 | 2008 Dodge Ram Pickup 1500
Break Light wiring diagram for 1998 dodge ram 1500
haynes repair manual has a brake switch diagrame
Feb 11, 2010 | 1998 Dodge Ram 1500 4WD
I NEED A FAN BELT DIAGRAM
James,
Reply with an email address and I'll email it to you. FYI, my AllData only shows the 4.7 liter engine used from the 2002 model year and newer.
Charlie
Jun 18, 2009 | 2001 Dodge Ram 1500 Truck 2WD
2006 hard starting will not stay running, then no power at all.
What happens when you turn the key?... is there a clicking or clunking noise?... try tapping the starter and the solenoid that is attached to the starter and see if that helps. It may help if you have someone else turn the key while you tap on the starter and solenoid.
May 06, 2009 | 2006 Dodge Ram 1500
1999 Dodge Ram 1500 4WD Crew Cab - Alaram goes off when opening doors even after using key to open.
I have a 98 Dodge Ram 1500 4wd with an alarm and have the same problem. No big deal for me though as long as I have the remote. You can shut off the alarm by pushing the redlight that blinks on your console. That is usually what I do.
Aug 31, 2008 | 1998 Dodge Ram 1500 4WD
Icbm-7071 performance teknique alarm remote starter wont work
what type of vehicle and year is it in? Also, most remote start alarms have a neutral safety wire that needs to be grounded and a hood-pin wire that needs to be connected. If the start system was working and has since failed, it is pointing at the hood-pin wire. If it never started remotely, then you may look to the programming on the alarm. Make sure that the tachometer wire is connected and that the tach setting has been programmed. This should take care of it. If not, I would recommend visiting a local stereo shop to have them diagnose what is wrong with the system.
Aug 09, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
195 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
