Question about Acer TravelMate 3270-6569 Notebook
Battery Is there an innitial charge that needs to be done before using the notebook i.e how long do I need to charge the battery for?
  • 145 Answers
Generrally I recommend a 24 hour charge but 8 to 12 hrs should be sufficiant.
Posted on Jan 19, 2008
Laptop will not charge battery. Issue with internal power converter, etc.
The motherboard has charging circuits built in to regulate the charge to the main battery, in rare causes it fails leaving a choice to attempt a repair or replace the motherboard. I suspect this is what has happened to your system.
Apr 05, 2012 | Lenovo IdeaPad U550 (374955U) PC Notebook
Acer aspire 5935g battery problem
Many users do not use their notebook/notebook batteries correctly. The battery in a laptop/notebook/netbook is a rechargeable battery, like the battery in a Cellphone, a Digital Camera an eReader or an MP3/MP4/MP5 Player. This type of battery needs to both charge and discharge, if it is to perform to its maximum capacity and have a full, long life.
You would never dream of using a Cellphone, Digital Camera, an eReader or an MP3/MP4/MP5 Player only with the devices permanently connected to the mains electricity, because they are all devices that are designed to be used while the user is moving around whether indoors or outdoors, powered by their rechargeable batteries. the batteries of such devices are only recharged when the charge in their cells is depleted and then only for as long as it takes to restore full charge to them.
As with the other devices mentioned, a laptop/notebook/netbook's battery is designed for mobile use and the user should charge it to 100% full and then stop charging it to then use the device on battery power alone, until the battery is low on power, when the recharging cycle can then be repeated.
A notebook/netbook has more flexibility than the other devices mentioned because, unlike the other devices, it can also be powered directly from the mains electricity, without the battery installed.
If your laptop/notebook/netbook is mainly used away from the home or office, it is fine to leave the battery permanently installed. If, however, it is mainly used indoors at home or at work and always or almost always on exactly the same desk or table, then it makes little sense to use it either on battery power alone or with the battery permanently installed.
Charge the battery up to full charge and then disconnect the battery from the device and keep it safely for when you next need to use the laptop/notebook/netbook on the move (if the battery is stored for long periods it may require additional recharging to both maintain the battery's condition and to keep it fully charged because low level power dissipation takes place in a disconnected battery). Then connect the device to the mains electricity without the battery and continue using it like that.
If the laptop/notebook/netbook is mainly used in a single permanent indoor location, then charging has to stop when the battery has reached 100% full charge and should only be resumed when the device gives a low battery charge warning.
It is also important not to let rechargeable batteries drain completely by ignoring the low battery charge warming and continuing to use the device until the battery runs out of charge and the device powers down suddenly. Sudden shutdowns like this are neither good for the battery nor the device and can shorten the lifespan of both.
Continuing to charge any rechargeable battery when it has already been fully charged damages and shortens the life of the battery. It can even damage the internal Power Management System of the device if done over a sustained period of time and/or for prolonged periods of time.
When your notebook only shows 75% as the maximum charging level, this is an indication that one or more (probably two) of the individual cells that make up the battery are fully depleted, damaged and probably no longer capable of storing a charge, for the reasons given above. You should stop charging this battery after it has reached 75%, otherwise more cells are likely to become damaged and so on until the entire battery is dead, unresponsive and useless.
Nov 20, 2011 | Acer Aspire One PC Notebook
Does not work without battery, recognizes that its plugged into charger and says its charging but its not
Hello, Thank You for using
Many times the case would be with the battery itself. A replacement battery could help your case here. A battery not being charged means the cells inside the battery are damaged from age, overcharging and other common issues.
I would first replace the battery, if the battery is new and its doing this then the charging unit inside the Toshiba is defective and would need a motherboard swap out. Mother boards for this unit could be crazy expensive. So it would be wise to replace the battery if that has not been done first.
Please update me with what you find.
Jul 11, 2011 | Toshiba Satellite L500 Series Notebook
A/c adapter will not charge battery. Got a new one, will not charge and shuts off laptop. Little battery life left on laptop,
you got new a/c adapter or new battery? If you got new a/c adapter then you need to replace the battery... thats what it sounds like:)
Batteries wear out over time and usage. To get the best use out of your battery try to always charge when little power is left:) Thnx
Jul 24, 2010 | Dell Inspiron mini 9 - Black , Intel® Atom...
HP Pavilion DV5000 battery charging problem
Sounds like you need to calibrate the battery, it is supposed to be done every 3 months. If it is not done, your battery will display the same symptoms are you describe. Yes, this holds true for adding a new battery also.
Here is HP's instructions on how to do it. You want to scroll down to the section called "Calibrate the notebook PC battery".
Feb 27, 2010 | HP Pavilion dv5000z Notebook
MY presario M2000 notebook will not power on.
how about the battery of the laptop, have you aleady check it? if you can find a working identical laptop like the one that try using the battery and see what happens if it will work or not, if it work then you have a battery problem and needs replacement
Nov 28, 2009 | Compaq Presario M2000 Notebook
Use a voltmeter to check your charger. If it is producing what is marked on it, then the charging circuit in the Dell motherboard has gone bad.
Replacement of the external charger is easy, the motherboard needs to be done in the shop.
Oct 21, 2009 | Dell Vostro 1000 Notebook
Keyboard and Touchpad not working
When the batteries on that laptop no longer hold a charge it will cause teh problem you indicated. Remove the battery and restart from the AC power to check. If that fixes the problem you need to go into the devive manager and turn off the Microsoft battery manager. This will allow you to reinstall the battery without the problem.
Jan 07, 2009 | Acer Aspire 3003LCi Notebook
Battery not charging
How old is the battery? If this laptop is a couple of years old, you may need a replacement, depending on how many recharge cycles have been done.
Dec 30, 2008 | Gateway MT3705 Notebook
Wont turn on
Sometimes you have to give it a half hour or so of innitial charge
Sep 09, 2008 | T-Mobile Sidekick ID Cellular Phone
Acer TravelMate 3270-6569 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
