Question about Sony Cameras
When I use the zoom buttons it automatically turns the camera off.
    President:
  • 2,761 Answers
If the camera has recently been dropped you may have lens damage that is preventing it from operating.. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Posted on Dec 10, 2009
My Coolpix L320 was working fine, then all of a sudden got stuck with the lens zoomed all the way out and a message on the screen that says, "Turn the camera off, remove the lens cap, and turn the cam
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Jan 18, 2015 | Nikon Coolpix L320 Black Digital Camera...
The zoom on the sb600 wont adjust accordingly to the zoom of my lens
Three things come to mind.
First, make sure that you are in fully automatic mode - easily done by reset (holding down "Mode" and "On/Off" at the same time. If you hit the "zoom" button it takes it out of automatic zoom and cycles through manual zoom settings until you get to auto again.
Second - make sure the camera is in an auto mode - manual mode could stop it from zooming.
Third - make sure that you don't have the diffuser pulled down. That can keep it from zooming also.
Mar 30, 2010 | Nikon Speedlight SB-600 TTL Flash
Camera automatically zooms when I turn it on and the buttons are not working
hi
Some of those buttons work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously.
If this is not the issue, please describe specifically which buttons are not workin...
thank u
rate me!!
Aug 24, 2009 | Panasonic Lumix DMC-FX30 Digital Camera
Frozen
You have a stuck zoom switch. The fix will require opening the camera, see the following link. This detailed fix is courtesy xscrewdriver (nice job xs).
Aug 01, 2009 | Canon PowerShot A560 Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
JVC GR-DX97 Zoom Control Button on top
You have a bad zoom unit/zoom controller. It is common on these units.
Oct 22, 2008 | JVC GR-DX97 Mini DV Digital Camcorder
Zoom malfunction
I had exactly the same problem. You just need to smash once with your hand on the bottom of your camera (it looks that this works for all canon cameras).
Jan 08, 2008 | Video Cameras
FX8 all button frozen
I am not sure if this is a solution. but one time, i turned on my camera when the battery is really drained. usually (when it was broken) it will automatically zoom in. but that certain period when i turned it on, even before it can zoom in, the battery drained and the camera went off. i charged the battery and when i put it back and turned on the camera, it works fine. it is still working fine. good thing i didnt had the repair center fix it, because they charge really high price.
Nov 11, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Zoom malfunction
the zoom control button is malfunctioning. try to clean the contact. check the resistant of the variable carbon. if it is not open, try to adjust the contact point away from the damaged area.
Oct 18, 2006 | JVC Handycam GR-DX77 Mini DV Digital...
Difference between the D-460 and the D-450 Zoom digital camera
The D-460 Zoom shares the following features with the D-450 Zoom: •1.3 megapixel resolution - 1280 x 960 pixels •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •2x digital telephoto mode •3x image magnification inspection mode •Sequence mode: Up to 10 images at 2 frames per second intervals (SQ mode only) •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self timer •8 MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings (125, 250, 500) •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-460 Zoom has the following functions and features: •Industry standard icons for button labels and operation menus •Easy to use jog dial and button design allows easy menu navigation •2 compression ratios are now selectable in SQ mode •Selectable Sharpness: Normal or Soft •Selectable Memory Mode Setting: Reset camera settings at power-off or Retain all camera settings •2 Olympus brand CR-3V long life lithium batteries included. Provides 20-30 times the power/life of alkaline batteries
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Cameras Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
