Shutter stuck open after a tree limb struck it
  • 143 Answers
If the lens is physically crooked, then gently try to push or pull it back into place. It may take a little force. If It wont, then the Lens assembly will probably have to be replaced. Try ebay, or partstore for it. Your local electronics store might be able help you get it fixed.
Posted on Dec 10, 2009
    Sergeant:
  • 186 Answers
Hello. Sadly this is a very common usually fatal problem.With little to loose try firmly smacking the bottom corner of the camera below the lens in the palm of your hand while powering up. Don't hit the lens itself. Also Dropping it on its back from 2 or 3 feet onto thick carpet while powering up may work. Lens replacement often costs nearly as much as a new camera these days.
What are some tips to cut tree limbs by a pole saw?
safety helmet
safety glasses
cut smaller branches first
cut small lengths
have a friend as a look out for power wires and other obstructions that branches can fall on
never cut while on a ladder
use a trestle and not a step ladder
Apr 09, 2018 | Garden
What is the benefits of using a telescoping limb saw?
hi,the benifits are that you can reach the limbs you need to cut from the ground,hope this was of some help all the best.
Mar 14, 2018 | Garden
Maple tree spots on limbs
may be Verticillium wilt.
May 12, 2014 | Garden
Maxon mcb 10a
this can be a couple of reasons. One if the antenna hit a tree limb it could be damaged and or it could have affected the SWR. Generally that is what happens why you not being able to tx/rx very far. Then also it can be just conditions outside not favorable for long distance talking.
Jan 14, 2018 | Radio Communications
Husqvarna Chainsaw 350 has a piece of the plastic that around the handle broke, what kind of glue can i use?
Replace the handle. You can order the parts from partstree.com and it should be less than $30.00. If your saw runs fine its worth it.
Mar 24, 2013 | Husqvarna Garden
I bumped the right limb on a tree and have been shooting right about six inches
Make absolutley sure you didnt crack the limb. This could be very dangerous. If its not cracked , can you not just re adjust your sights ? The vibration could have just knocked them off.
Oct 24, 2012 | Barnett Crossbows Barnett Jackal...
I took camera to a desert and since then the shutter has been stuck open. It may have been the heat or the vibration from the motorcycle I was on! Any ideas please???
The fault of a lens error be it in the shutter, zoom or auto focus is due to failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to
Aug 04, 2011 | Cameras
What's the best way to use my 16 in electric saw to cut off tree limbs?
This is somewhat subjective. Eveybody does it a little different.If you are cutting limbs from a tree, start an undercut about where you want the limb to fall free of the tree. Use the upper edge of the chain to cut it about a fourth of the way through. Then start from the top of the limb over where you made the undercut.
Sep 25, 2010 | Remington 16" Electric Chain Saw
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
