Question about Whirlpool GST9679P Top Load Washer
Wahing machine does not spin
Machine fills with water but does not spin making loud noise
    Scholar:
  • 68 Answers
The coupler is bad, this unit does no have a belt. has a motor coupling installed.
i have seen video's on youtube about how to do this in the past, its not hard
part number 285753A buy it here http://lartoday.com/order_parts.htm
lebarchrigen appliance repair
www.lartoday.com
Posted on Dec 10, 2009
Machine Starts filling then spins 3 turns and a loud noise and stops?
Hey friend, I appreciate your post!
From my understanding you Frigidaire washer will fill with water, spin three times, make a loud noise, and then stop. You could possibly be seeing an issue with your control panel or motor. I would recommend having a technician come out to the home to properly diagnose and repair your washer. I hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Making loud whine/growling noise while filling with water
Is your machine loud on spin cycle as-well,
Your seal and bearings need to be replaced.
Mar 02, 2013 | Fisher and Paykel GWL11 Top Load Washer
Wahing machine makes a loud banging noise
This could be due to pending failure of the flexible joint beneath the tub
Jan 22, 2013 | Kenmore Washing Machines
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Washer will not fill or spin, makes a loud noise
The timer is likely failed if both these are happening simultaneously.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Whirlpool GST9679P Top Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal De
