Question about Refrigerators
Can I transport a new (factory sealed) refrigerator on its back?
  • 5,081 Answers
If you have to lay the fridge over, try to avoid laying it completely flat. Instead tip it to an angle by placing a box under the top of the fridge; this will help to keep the oil in the compressor. Also, there are several lines connected to the compressor. The cooling and discharge lines should be oriented to face up. You must keep the oil out of these lines. Laying the refrigerator over with the tubes facing up will minimize the risk of fouling the lines.
When you have the refrigerator in place at its destination, leave it upright for a few hours before plugging it in. This will give the oil an opportunity to flow back into the compressor. After plugging it in, it is not unusual for the fridge to take up to 72 hours to return to its low temperatures, especially if the fridge is empty.
Posted on Dec 10, 2009
  • INDIRA KUMAR
    INDIRA KUMAR Dec 10, 2009
    If after all your effort the refrigerator won't cool, your refrigerator may be in its defrost cycle, so be patient, about 6 hours, for the cycle to complete. Otherwise, there may be oil in the lines. In that case, you will need professional repair.
    Moving Tips:
    • Don't try to move a fridge with it's contents. Empty the refrigerator first. The contents adds a lot of weight, it will shift around during moving and will make it more prone to tip over.
    • Tape the doors closed.
    • Wrap the fridge in a protective cloth to avoid damaging the appliance and to reduce the risk of damage to the walls in your home.
    • Use a dolly or hand truck to move a refrigerator.
    • Don't put straps over door handles to avoid damaging them.
    • Don't overtighten straps or the door may become warped or be pulled out of alignment.
    • Always have adequate assistance when moving a refrigerator, it is very heavy.
    • Follow all appropriate safety precautions.
    Genius:
  • 1,341 Answers
You cannot tell unless you know exactly how the package is inside.Basically most fridge has the pipes at the back which looks like a grill and if this damaged then the whole fridge will not function.
  • Refrigerators Master
  • 1,606 Answers
You can transport it , but after reaching destination , it MUST stand up for 24 hours , before plugging it in . This will allow the oil in the compressor , to go back into the compressor , from the lines when laid down .
May I safely transport a refrigerator laying on its side?
yes,but let it sit still after you stand it up for 24 hours without plugging it in to allow the freon to settle
May 14, 2015 | Refrigerators
We sold our bosch dishwasher, working perfectly. New owners transported it on its back. Now it won't start, or even show that it is getting power, though the outlet works. What has happened?
Hello KT;
My name is Peter. I am a retired field service appliance technician.
Transporting the dishwasher on its back should not have been a problem. It is only with refrigerators and freezers that need to be transported up right, to prevent compressor oil getting into the refrigerant sealed system.
You may have a power cord problem. You have a 3 or 4 wire power cord. If you have a 3 wire power cord you need a 15 amp circuit breaker. If you have a 4 wired power cord you need a 30 amp circuit breaker.
The wall socket that you are plugged into my not have a ground.
You need to check the wall socket and the wire connects at the dishwasher. Send me a model number so I can see what you have. If you have a 4 wire connection you can chance the cord to a 3 wire. On a three wire you have a neutral and two hot with a small green ground wire. On a 4 wire you have a neutral two hot wires and a neutral in the center with a ground wire.
I would put my money on the wall socket not having a ground.
Send me a model number and I will help you.
Feb 07, 2015 | Bosch Dishwashers
Just had a candy fridge Cfle 5485 w and as we unpacking it notice the back has a black seal. Is this just a transport packaging or should this be removed when using.
your question is not clear, better attach a picture. to be safe, if it is no bother for you and you do not see the back, just leave it there
Dec 24, 2014 | Refrigerators
Moved unit, wont get cold
did you transport it upright or laying down.... depending on who you talk to you will get a different answer... i have been in the appliance business for 18 years and have to say the more i hear they are transported laying down the more i hear troubles... either way after transported or moved they should be left sitting for approx. 24 hours to allow all the oil to settle back down,,,also could have developed a leak in the sealed system one of the refrigerant lines leaking.
Feb 14, 2011 | GE Refrigerators
I just sold my Magic chef refrigerator (20.8 cu ft). It was 2 years old . I plugged it in for the buyer. It got cold as it worked perfectly. the buyer said he was going to lay it down to transport it...
i have been i the appliance service industry for approx. 18 years and everytime i see someone lay a refrigerator down or talk about it i literally cringe.... it can be done and sometimes will work ,but what happens if it does not sit upright and notice i said and all the oil runs back down it will fail everytime.... the oil gets in the evaporator and then will not run correct when the compressor comes on it pushes that oil through system and will clog capillary tubes and or slug unit creating it not to pump properly.... guarantee this is what happened to the unit... if it indeed worked fine before you sold it he either allowed oil to saturate the evap coil or something in the sealed system broke in transport causing freon to leak out...
Jan 26, 2011 | Magic Chef CTB2125 Top Freezer...
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Can I transport my brand new Whirlpool on it's side?
It's certainly not recommended because you can fill and clog the refrigerant lines with oil from the compressor.
IF YOU MUST...your chances are better if you leave it upright for an hour or so before plugging it in. This allows the oil to drain back into the compressor. This period should be appreciable longer in cold weather as the oil is thicker.
Sep 12, 2009 | Whirlpool Refrigerators
Is it ok to transport a refrigerator on it's side?
Not true. Refers since the 1950's are sealed units but for safety's sake let it sit for awhile after you move it.
Aug 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Tape over flat circles of styrofoam on the back of the Frigidaire
No! These arethe insulation fill points. This is where insulation was blown in at the factory. they need to remain sealed.
Apr 04, 2009 | Refrigerators
Both top freezer and bottom refrigerator not cooling
If everything is running i.e. evaporator fan, condensor fan, and compressor then you have a sealed system problem. If the compressor is not running it may have a bad start device (relay and overload) or thermostat/control board (will have one or the other). I would try a new start device first if the compressor isn't running. If you put a new start device on the compressor and it doesn't start then the compressor is locked up and would be better to buy a new fridge. Hope this helps. p.s. make sure there is no frost build up on back panel in freezer.
Oct 07, 2007 | Frigidaire FRT18B4A Top Freezer...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
