Question about Hotpoint WMM65 Front Load Washer
How do you change the door 'gasket'??
Would be really greatful if some one could explain how to get the old one off.
thanks
I have just changed the gasket for this machine - its very easy.
Firstly, you need to remove the spring clipped wire around the seal on the outside of the door opening - I used narrow nose pliers to squeeze the ends together and unhook and remove the wire. I then used my hand to remove the outer part of the seal from the door opening.
You then need to remove the retaining clip on the inside of the machine - this is easy if you push the seal into the machine (turn it inside out), this will expose a jubilee style screw clip on the upper right hand side of the drum. This can (just) be unscrewed and loosened through the door opening without the need to dismantle the machine from above. The second wire will then come away and you can remove the gasket fully.
Fitting is simple the reverse of the above. Take care to put the gasket on the correct way round (drainage holes at the bottom, slightly to the left) and not to snag the rubber when fixing the outer wire clip.
Should take no more than an hour.
Posted on Dec 27, 2009
    President:
  • 842 Answers
This is a generic solution, so there may be very slight differences for your machine, but it should still work.
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until ot is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
Posted on Feb 09, 2009
Why is the top of freezer frosting up
The door gasket is leaking around the top of the door. Air getting in past the gasket condenses in the freezer causing the ice build-up.
Sep 07, 2014 | Freezers
How do I install the front rubber gasket on a Duet HT
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back with your MODEL NUMBER and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
May 20, 2010 | Washing Machines
I have a sliding shower door in my bath but unfortunately, I do not know the manufacturer of it. It's about 14 years old and the bottom plastic part that is attached to the bottom of the door has broken...
there is a good chance you won't find this part for a number of reasons,...you'd be best to either change the door (with a "basco" door, great company) of if your feeling some oats, make the part you need.
Nov 20, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Head gasket repair on the v 8 4.0 engine is it hard to do?
Very difficult, especially if you have never done one. This requires high precision tools and mechanical capabilities. You are advised to leave this one up to the professionals. Believe me, I still remember MY first headgasket and it drove me crazy back in 1969. Okay, yes, I'm getting old. Thanks, Dana.
Sep 30, 2009 | 1997 Oldsmobile Aurora
How to change door seal on zanussi fl 1080 . how do i remove old torn one and fit new
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install
Thank You for contacting Fixya.com
Aug 03, 2009 | Zanussi ZWF1440 Front Load Washer
I need to change the freezer seal on my refrigerator. But they did not send me any directions on how to do it.
most of these have a hardened plastic female channel thats tough to see . it is a part of the door and consealed under the old gasket. it has a hollow groove . usually the new gasket has a flat side with a dart or double dart piece sticking out . this dart or arrow side runs the entire side of the gasket and smushes into the door groove channel.. usually you start on a corner firmly pulling out the old dart and gasket from the channel groove. clean the old channel with mild detergent and a little brush. wipe down. lightly oil door groove channel with a little veg oil on a rag and get ready to mash the new dart onto the channel all the way around. it takes great finger strength and mashing one thumb on top of the other to get enough pressure but it can be easy on some. good luck .be sure to clean door sill mating surface and wipe with oily Veg oil rag so new gasket stays clean and doesnt stick. it may take a few days to break in and level out. be sure your snug all around when done. lay out new gasket nice and flat in warm room before you start.
Oct 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Replacing the boot gasket
Try following this link :
http://www.applianceaid.com/boot.html
Many got help, didn't paste the entire thing here as didn't wanted to spam the site.
Thanks
Jul 02, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Changing the door gasket on Hotpoint Ultima WD860
Managed to work it out myself how to take the old door gasket off and attach the new one. Thanks. Machine working okay with no leaks or mould anywhere now.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Door gasket
You will find it will be better to change the whole door,you can get the seal but its a fiddly job.
Feb 23, 2008 | Asko W6021 Front Load Washer
Hotpoint WMM65 Front Load Washer Logo
100 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
