Question about GPS
GPS wont hold charge for more than a few seconds Unable to use it away from a charging source OK while connected to the auto charger. Item 5387 MD 96820 MSN 30008102
  • narvaezfrank Dec 13, 2009
    Since my GPS work fine while connected to a power source;
    and you stated that the battery must be replaced in order to use
    it as portable,
    How can I do it? Is it a common battery, easy to obtain locally?
    Or is there a repair place near Atlanta, GA?
    Genius:
  • 1,341 Answers
These devices must have a battery but most will need disassembling in order to change this part.This is the only reason it will not hold any charge.
Posted on Dec 10, 2009
  • heeman mohun Dec 13, 2009
    I would suggest you do a google search for this particular made and its battery.If it was me I would do a quick search on ebay as it is quite amazing what sort of deals you can get there.
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
It keeps freezing and battery wont charge
Usually when the battery doesn't hold a charge anymore (even if you've plugged it in to a power source for quite a long time), the device will not longer work ... i.e. it freezes or shuts down. That's because the GPS uses power from the battery and not from the AC power source (that is plugged in and charging the device).
Replacing the battery may bring it back to life ...
Aug 26, 2013 | Tomtom GO 720 GPS Receiver
No GPS signal
Ok Marilyn,
Thanks for the info. Your device has no dedicated reset button like some other Tom-Tom units, but it still can be reset.
To perform a reset, make sure that the unit has a fully charged battery. Charge for several hours if unsure - and make sure the charging light comes on (if it doesn't - it will probably need service) while connected.
Disconnect from charger.
Press the On/Off button to turn the unit on (if not already on) and allow it to start up as usual.
Press AND hold the On/Off button for up to 15 seconds or until the unit turns off.
The GPS should now be reset, and should work as expected when you next turn it on. Good luck!
Apr 15, 2012 | GPS
Garmin gps powers off even when fully charged
If you're "recharging" via the car charger - you might want to try charging via USB jack on your computer - or AC adapter (if your GPS shipped with one) for 5 or more hours.
Many Garmin units develop this condition when used strictly in the car / cigar outlet power source. While connected to your computer, you should go to Garmin's website and download, install & run the "webupdater" software. When complete, your Garmin GPS will have the latest firmware and patches to the software (not maps!).
After charging via USB or AC adapter, your GPS should stay on. If your GPS turns on via a slide switch on the top, Slide the switch from OFF and hold in the ON position for 10 seconds before letting go of the switch. This should force a "boot" on the GPS.
If you're unable to get the device to power up, contact Garmin Support to determine if your device is affected by a a recent battery recall or if there are other suggestions they have to solve the problem.
I hope this helps!
Oct 08, 2010 | Garmin nuvi 650 GPS Receiver
Hi i get the greeenlight on charging but then wont turn on sally
if the unit has been unplugged for a while and the battery has gone flat, you will need to hold the on button for a few seconds to re start it. After that , it will be ok. Just a short push of the button as usual
Oct 02, 2010 | Tomtom GO 510 GPS Receiver
Battery losing charge whilst plugged in to cig lighter
I have the same problem, when the battery goes dead, it seems to do so instantly vs. just holding the charge for less time. You can replace the battery, but with the prices coming down and the fact that the map upgrades cost what they do, I'm thinking it's more cost effective to just buy a new GPS.
Apr 18, 2010 | Tomtom ONE 3rd Edition GPS
My garmin wont turn on iv tried charging in car, computer, changing fuse, it just wont turn on
plug it in to the computer for a few hours, then hold the power switch to the on position for up to 15 seconds.
if that fails, disconnect it from the power source, then press and hold the lower right corner of the screen, while holding the lower right corner, switch the power to the on position. once you see the message "do you really want to delete your data" select yes, then follow the on screen instructions
bill
Nov 23, 2009 | Garmin nuvi 765T GPS Receiver
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
or buy the port here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My mp3 wont turn on
Check if it's fully charged. Try connecting to different charging source. Press and hold the Reset button for 30 seconds then try connecting to charging source and try turning it ON. If the player doesn't respond send it for service.
Aug 25, 2009 | Audio Players & Recorders
Garmin Nuvi shuts itself off after only seconds during navigation
Is the battery charged? What does the battery indicator say? If you are using it in the car, is the power cord connected and working properly? If it is working correctly, you should see a lightning bolt symbol over the battery bar graph showing that it is connected to an external power source and that it is charging.
- Jim
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
