Win 2k, XP, Vista, and Win7 have a CONTROL PANEL applet called Administrative Tools - opening that there is a sub applet called Computer Management - and openint that there is another sub applet called Disk Management. In Disk Management you will usually find all of your drives (including those that don't show up in Windows Explorer). A new drive will probably be listed as drive 1 or something like that and shown as UNALLOCATED space. Right click that drive (my best advice on how to be sure its the right drive is to know the drive size .. ie 500 gb or 750 gb etc AND seeing that it is inactive) to activate it and to partition and format it.
Try Device Manager. Right click on My Computer, go to Properties, then click on the Hardware tab, then click on Device Manager. Click on Disk Drives and see if it shows up there. If you see what could be your drive, right click, then click on properties and then at the bottom of that window, you may have a drop-down box which you may be able to enable the device there. Hope that works.
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
