Question about Microsoft Xbox 360 Console
Xbox 360 my xbox 360 is having three ring problem and it's overheating
  • 26 Answers
The three ring can mean av cable error nd overheating can be fixed you can buy fans for them from all good games shops there external
Posted on Dec 10, 2009
3 red rings on power button
this is a common problem with the 360 the system has overheated causing the heat sync to break there are many sites were you can order replacement kits. just type three light ring of death xbox 360 from your search engine i rec. llamma
Jan 09, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My 360 has 3 rings the rings are red and it wont turn on
The three red lights mean that your XBOX360 is experiencing hardware failure. This is caused by overheating of your XBOX. Contact Microsoft and have them fix the problem. They have given free extended warranty for three red light problems. If you have bought your xbox360 within 3 years, you're in luck.. They will fix your console for free...
Mar 13, 2010 | Microsoft Xbox 360 White Console
Have three red rings on 360
Means your xbox is overheating
Jan 23, 2010 | Microsoft Xbox 360 Console
Three red rings of death
The 3 red rings is the most common error with the Xbox 360 it is a hardware problem caused by the GPU and the CPU overheating, you need to stop the heat build up, you can do this yourself or you can send it in and they will fix it for you.
Jan 04, 2010 | Microsoft Xbox 360 Console
Repair XBox 360
I can help with the overheating part. There are auxillary fans made to fit right on the XBOX. Fixing the 'Ring of Death" can be very complicated, depending on what all went wrong inside.
May 31, 2009 | Microsoft Video Game Consoles & Games
Can you fry your xbox 360
It has been overheated and needs to be reflowed. So if its still under warrenty send it in. If not pony up the cash to send it in and get a new one. You will most likely get a newer version motherboard and they stay pretty cool...
May 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 2 rings
One red light signifies a major hardware failure or system error[4] , depending on which hardware failure or system error it is depends on how the problem can be fixed but in some cases there is no easy recovery and the console must be repaired or replaced. Two means the console is overheating and must be switched off and left to cool. Three, the infamous 'Red Ring of Death', means a general hardware failure and the console must be sent to Microsoft for repairs. All four red lights simply means that the console cannot detect its AV cable.
Nov 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 fix
Towel solution wouldn't make sense if unit is overheating.
Best bet is contact microsoft and send it in for repair.
Mar 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
