Question about Dual Electronics CECT P168 Cellular Phone
I have applications on my sciphone that i want to be removed. How do i do this? is there any application/software that i can install in my PC to do this?
  • 61 Answers
Is it i68 or i9+? You can not remove it by yourself if Yes, only factory can make it for you, ask help from your seller.
but for new model Sciphones, you can make it, like C5, C6, W902, 3GS....you can browse them at: www.eshopbing.com, good luck!
Posted on Dec 11, 2009
I want to disconnect/remove an external GE water filter for a refrigerator from the copper lines that go in and out of the filter. They were pushed in place to install, but how do I get them out?
Install applicationsYou can transfer installation files to your device from a compatible computer,download them during browsing, or receive them in a multimedia message, as anOther applications© 2010 Nokia. All rights reserved.106
e-mail attachment, or using other connectivity methods, such as Bluetoothconnectivity.
You can use Nokia Application Installer in Nokia Ovi Suite to install an applicationto your device.
Icons in Application manager indicate the following:SIS or SISX applicationJava applicationwidgetsapplication installed on the memory cardImportant:Only install and use applications and other software from trustedsources, such as applications that are Symbian Signed or have passed the JavaVerified™ testing.
Before installation, note the following:
? To view the application type, version number, and the supplier or manufacturerof the application, selectOptions>View details.
To view the security certificate details of the application, selectDetails:>Certificates:>View details. Control the use of digital certificates in Certificatemanagement.? If you install a file that contains an update or repair to an existing application,you can only restore the original application if you have the original installationfile or a full backup copy of the removed software package. To restore the originalapplication, remove the application, and install the application again from theoriginal installation file or the backup copy.
The JAR file is required for installing Java applications. If it is missing, the devicemay ask you to download it. If there is no access point defined for the application,you are asked to select one.Other applications© 2010 Nokia. All rights reserved.107
To install an application, do the following:
1. To locate an installation file, selectMenu>SettingsandApplication mgr..Alternatively, search installation files using File manager, or selectMessaging>Inbox, and open a message that contains an installation file.2. In Application manager, selectOptions>Install. In other applications, selectthe installation file to start the installation.
During installation, the device shows information about the progress of theinstallation. If you install an application without a digital signature orcertification, the device displays a warning. Continue installation only if you aresure of the origin and contents of the application.To start an installed application, locate the application in the menu, and select theapplication. If the application does not have a default folder defined, it is installedin the Installed apps. folder in the main menu.
To see which software packages are installed or removed and when, selectOptions>View log.Important:Your device can only support one antivirus application. Havingmore than one application with antivirus functionality could affect performanceand operation or cause the device to stop functioning.
After you install applications to a compatible memory card, installation files(.sis, .sisx) remain in the device memory. The files may use large amounts of memoryand prevent you from storing other files. To maintain sufficient memory, use NokiaOvi Suite to back up installation files to a compatible PC, then use the file managerto remove the installation files from the device memory. If the .sis file is a messageattachment, delete the message from the Messaging inbox.
May 07, 2018 | GE Refrigerators
Can't uninstall produtools app on a mac
Thank for contacting Fixya, I will be glad to assist you.
There are two very good software removal applications I can recommend you use, which will allow you to cleanly and safely remove unwanted software applications from your Mac.
One is called App Cleaner and the other is called AppZapper.
Both of these applications are easy to download, install and use.
They also remove the master applications, their main files and directories, but will not remove any child files (i.e. files you created from the original application), just in case you want to re-install the same application you delete once again, for any reason.
They are free to try and inexpensive to buy, so give one (or both) of these software removal apps a try.
Hope this helps.
Regards,
-The MacTechTrainer
Jul 31, 2012 | Computers & Internet
How can i put a themes in my nokia n95 8gb?
Hi
Before installing any software go to
Menu> App.Manager> Options> Settings> Software Installation
In Software Installation make it ALL. This change is important, otherwise you will get an Error message Certificate Error. Contact the application supplier while installing most freeware
Also, if you see that some old themes are giving the Expired Certificate error, simply change the date of your phone to year either 2005 or 2006 or 2007 (check all as each theme has a different expiry) before installing the theme. After installation you can change back to today's date.
Now, here is the way to install themes and other applications in your Nokia . I use the USB Cable to do the installations.
1. First install the Nokia PC Suite software on your computer from the CD which you recieved with your Nokia
2. After Nokia PC Suite is installed in your PC, connect the Nokia to the PC with the USB cable which was provided in the box.
3. When the USB cable is connected, Nokia PC Suite will recognise that a phone is connected. You will then see an option on your phone?s screen asking if you want to connect via PC Suite or Data Transfer. Choose PC Suite.
4. Now, simply download the .sis or .java files (themes & applications) to your computer and Right Click on it with your mouse. You will see an option saying Install With Nokia Application Installer
5. Click Yes on the PC, and then Yes & Continue on the Phone when you see the prompts.
6. The phone will then ask you if you want to Install the Theme or Application in the Phone Memory or Memory Card.
I strongly recommend Installing themes in the Phone Memory! This helps in avoiding complications later on when Uninstalling.
When I first bought the Nokia N95, I made a mistake which a lot of new S60 3rd Edition users make, that is, I installed the Themes in the Memory Card instead of the Phone Memory. This was a huge mistake!
There is a bug in the Operating System of all S60 3rd Edition phones, due to which, if the theme is installed in the Memory Card, it cannot be deleted or removed, as it then does not show up in the Application Manager.
Ever since that mistake, I have made sure to always install themes and softwares in the Phone Memory, instead of the memory card. Yes, it eats up space on the phone, but it's worth it, as then it is easily removed as well.
And that's it, the theme or application is now installed!
Thanks for using Fixya.
Mar 14, 2011 | Nokia N95 Cellular Phone
My nokia 3310c when dowloading applications, after reaching 100% download it shows a message application error.
It means the application installer not compatible with your phone. i.e. the application file is .sisx for Symbian S60v3 which is not compatible with your device. Or the file is broken or outdated.
When you download any application software, make sure its compatible with your phone. Your device can only install JAVA application so you can download application with .jar extension. And choose application with proper size for your screen (128x160 pixels), if its too big, it wouldn't able to be installed too.
Hope this help and if helpful RATE please.
Feb 03, 2011 | Nokia 3110 Cellular Phone
I am getting "Invalid Application"
DOWNLOAD THE APPLICATION TO YOUR PC
AND THEN INSTALL USING NOKIA PC SUITE
Jan 20, 2011 | Nokia 3110 Cellular Phone
How do i install the java game on my 10 page menu on my sciphone
You can do this by drag and drop. First, create a file in the memory card, lets' called it Java. Now, hook the usb cable from the computer to your phone, you must see in the phone's display a prompt: 1. Mass storage 2. Camera 3. Pict. Bridge. Let's tap on the very first one, Mass storage. The computer should recognize the new hardware and install all the drivers need in order to work. Pay attention to the letters assigns to the new hardware; one is for the memory card and the other one is for the phone's memory. To drag and drop you must have the Windows explorer enable, this means that you can see the main display, but at the left side is another window with all your storage and documents. Now, the Java applications that you have in your computer you are going to Drag and Drop to the Java folder in the memory card, do not decompress the application in the computer or it won't work. Once you had transferred the Java applications, remove the usb cable from the computer, and go the memory card in the phone, go to Java folder and open it. Tap on the application that you want to install, tap on install. Follow the instructions. to use the already installed Java application, just tap on the Java icon in the desktop, tap Java, and choose the application to be launch. Good luck.
Dec 17, 2009 | Lands Phones
Phone erases text messages and call log
This happens because of large applications are installed on the BlackBerry smartphone.
To resolve this issue, complete the following steps:-
  1. Make sure that the BlackBerry Device Software is installed on the computer to display the correct total application space.
  2. Determine the application space that is available on the BlackBerry smartphone by completing the following steps.
a) Connect the BlackBerry smartphone to the computer.
b) Open the BlackBerry Desktop Manager.
c) Double-click Application Loader.
d) At the Device Application Selection screen, under the application selection window, note the total application space.
NOTE:-Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes.
3) Remove applications that are not required. For example, remove additional language packs and themes.
Nov 07, 2009 | RIM BlackBerry Pearl 8100
Sciphone i68+ - Cannot remove Chinese browser-Opera Mini affected
You can overwrite the browser by downloading the application (.jar)on to the PC then connecting your phone by USB and then drag and drop the file in the appropriate folder on your phone. Then install the new browser like you normally would. The application will ask you if you'd like to overwrite the old settings --- say yes
Jun 08, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Application prob..
have you tried to remove the nokia software off your computer then re-installed that, then tried getting that application again?
Mar 20, 2009 | Casio Parts Cash Register PC Desktop
Sci-phone applications
Most of these I68 SCIPHONES have the same imei number, and alot of these are being blocked. So dont be suprised if you wake up one morning and it doesnt work.
Mar 18, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Dual Electronics CECT P168 Cellular Phone Logo
264 people viewed this question
Top Dual Cell Phones Experts
270rexton
270rexton
iphone service
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
