Question about Maytag MSD2456G Side by Side Refrigerator
Freezer not defrosting
This is the second time I've had to manually defrost my freezer in 4 months. What could be coasing that. Is there a deforsting circuit or a defrost module that may need to be replaced. How do I determine this. Once I deforst it it seems to work fine.
  • mazzop Jan 22, 2008
    Hello and thank you for your quick reply.
    I did have an ohm meter, with some trial and searching on the Internet I Think I've been able to determine that I have a faulty defrost termination thermostat, some kind of a timer switch which turns on and of periodically to defrost the coil. When removed this harness from the freezer I tested the thermostat. I could not get any reading on the ohm meter, I should have been getting a "0" reading, as per the suggestion on the Internet, but all I could get was OL. Which tells me that I didn't have any continuity through it. I will be trying to purchase this harness this Monday, I hope that's the answer. If not I will have to try something else.... If all fails I will call the Maytag man...although he must be busier these days ...they don't build them like they used to.
    Below I have attached some links I used as referance.
    Thanks
    Mario Azzopardi
    http://www.appliance411.com/faq/defrostp...
    http://www.partselect.com/refrigerator+t...
  • 447 Answers
What is the entire Model # and I can help with some troubleshooting as long as you have a volt-ohm meter and an amprobe would be helpful.
Posted on Jan 19, 2008
Freezer is cold but fridge is hot.is there a timer to defroze timer can it be faulty.need your help from ram.
try to check your evaporator fan if working. replace it if defective try it defrost manually then observe or check defrost timer and defrost heater rotate deforst tmer by your hand possible stock up thes thing you do if it is a build up ice in the freezer.
Feb 27, 2011 | Ariston Technologies Refrigerators
How do i get unit to go in deforst
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
The freezer is cool but not frozen
u'r defrost time clock needs replacing if u have a defrost refrig , u'r fridge is psobably warm as wellOR u do have a freon problem OR COMPRESSOR loosing capacity , it doesnt seem good for u :(
if its a defrost problem the freezer will be all frozen up and the fridge will be not cold
Oct 16, 2010 | Samsung Refrigerators
You got the right idea. your fridge have a deforst problem, and it can be cause by a number of items. 1. the timer, 2 the defrost temperature control. 3 the defrost element itself.
Before you use the hair dryer when there is ice forming in the back panel, try to turn the timer and see wheather you can set it to defrost cycle manually if you can then the timer need to be change. the 2 and 3 item is a bit more work for normal people to deal with, you better call in a serviceman and watch him how he handle it so you can try it yourself next time. God Bless
Jul 14, 2009 | Freezers
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
Whirpool frost free-fridge temp is not working
First Test Method:
Second Test Method:
� If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
� If the relay clicks two times, check for an open bimetal.
Jan 06, 2009 | Whirlpool Refrigerators
Freezer problem (icing behind cover inside of freezer)
Several things to check. Refrigerator needs to be put in manual defrost mode, then check defrost heater and defrost thermostat.
Jun 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Fridge side not cooling
you have a defrost issue, posslble heater, defrost thermo, or a defrosttimer, something not working correctly as of now you have a manual defrost refrig
Feb 18, 2008 | Kenmore 72073 Top Freezer Refrigerator
Maytag MSD2456G Side by Side Refrigerator Logo
111 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
