Question about Cell Phones
As i was in the middle of a text message. my Pantech c530 turned off by it self. Now everytime i try to turn it on, it flashes the AT&T logo and then shuts back off. i dont kno what the problem is, can anyone help?
My pantech burst will not receive text messages what do i do
I just turn airplane mode on and off if it doesn't work, and it fixes it everytime. you could also try sending a text to yourself, that usually makes all the messages go into your inbox, like a flood.
Aug 26, 2012 | Cell Phones
I need Pantech Slate's unlock code (Pantech Slate C530)
Good place to get a unlock code for your pantech C530 model mobile from this site Theunlockspot.com , here it gives the easy methods to get the mobile unlocked..........
Mar 20, 2012 | AT&T Pantech Slate C530 Silicone Gel Case
I purchased an unlocked pantech c530 and cannot send or recieve pictures through text/multimedia messages. Is there a solution?
hello,you can only send messages through multimedia if you have your internet settings/mms settings being activated on your mobile device,if it is activated you should be able to send the pictures.i would advice you call the customer service centre of your service provider to complain.
take care.
Jul 24, 2011 | Cell Phones
I need an unlockjing code for Pantech C530
you can get the unlock code for Pantech C530 www.prounlocking.com/pantech-c530... at reliable cost... i just unlocked my Nokia N95 .. its working well and good
Sep 27, 2010 | Pantech Slate Cell Phone
Need unlock code for pantech C530
you may try some default codes........
Aug 14, 2010 | Pantech Duo Smartphone
Unable to scroll down - txt messaging
well my pantech slate was doing the same thing, so what i did was turn off the phone, take the battery out and put it back in.
after i turned it on, it was fixed. voila.
Jun 01, 2009 | Pantech Slate Cell Phone
Can you turn the key pad off on the Pantech Slate C530 without putting my phone on silent or vibrate
In the menu, to to "Settings", then "Sounds & Alerts". Put the select bar over "Normal" (if that's the setting you use it on), pressing the "Options" button and selecting "Customize". Find "Keytone Type" and press the left or right arrow buttons to select "Off". Then select "Save". You can do the same for "Vibrate and Ring".
Apr 29, 2009 | Pantech Slate Cell Phone
Pantech Slate C530
In the menu, go to "Settings", then "Sounds & Alerts". Put the select bar over "Normal" (if that's the setting you use it on), pressing the "Options" button and selecting "Customize". Find "Keytone Type" and press the left or right arrow buttons to select "Off". Then select "Save". You can do the same for "Vibrate and Ring".
Apr 29, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Text Message Help: Pantech c300.
Maybe you have no sevice, or you might not have any minutes left on your phone.
Aug 24, 2008 | Pantech C300 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
