Question about Intermatic T104R 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw
Hello i have an intermatic model #t104r 208-277 volt my problem is that it works manually but it doesnt work automatically? whats wrong?
  • 565 Answers
If you can also manually turn the dial so that the load turns ON and OFF, then the timer motor is bad :-( Replacements are available here for about $30:
http://www.aplussupply.com/intermatic/timer.htm
Scroll down to "WG 1573", Timer motor 208-277"
Posted on Dec 10, 2009
How connect a new intermatic t104r 120v
T104 timer is 240Volts.
Not 120Volt
You can convert timer into 120V by changing clock motor from WG1573 to WG1570. This action will convert the T104 into T103.
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
The T104 timer can be wired many different ways:
Copy following link for illustrations showing both T104 and T103 wiring
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment with specifically what you are connecting to timer, and I will comment back with more detail as needed.
Oct 07, 2012 | Intermatic T104R 208-277Volt 40-amp Timer...
Timer not working?
Posted under Intermatic T100 series timer:
Open following link for troubleshoot and to identify replacement parts:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
If this is not your timer, then add a comment with model number or description of timer for possible help.
Aug 06, 2011 | Intermatic T104R 208-277Volt 40-amp Timer...
I would like to locate a manual for it
You posted under a photo that looks like Intermatic T104R outdoor 240Volt timer.
Model number usually appears inside timer door.
Add a comment if you have different timer that shown below.
Link to identify timer:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
Manual for T104
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Link below has Intermatic manuals.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Use find feature on your browser > click edit > click find > type in timer model number
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I need trippers for a paragon electic model # 4014-20 swimming pool timer
1) Paragon no longer makes timers and parts, except defrost timers.
4014-20 is not defrost timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
2) 4000 series uses X2772 tripper
Google search for this product shows these trippers selling for 50-60$
3) Intermatic cross-reference chart shows T104R 240Volt raintight is replacement
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
I saw T104R at Lowes today for around 90$
4) How to wire T104:
5) Add a comment for more free help.
For a price, fixya expert speaks with you over phone while you work on timer.
We are always less expensive than a service call.
Jan 14, 2011 | Hardware & Accessories
I have intermatic t104 time 24 hour, the door hinges are broken can i get new door.
Page below shows Intermatic boxes, but doesn't describe which timer fits which box.
And the box costs as much or more than new timer.
http://www.electricsupplyonline.com/prod/intermatic-timer_accessories.php
Amazon sells T104 indoor
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88/ref=pd_cp_hi_3_img
T104R raintight sold at Aplus
Jan 05, 2011 | Intermatic T104 24h 208-277v Mechanical...
Intermatic model T1O4R stopped working. time dial does not move
Can you turn the load ON and OFF with the manual switch? If not, the circuit breaker supplying the timer has probably tripped. Turn the breaker OFF, then back ON. Sometimes a breaker will trip, but it looks like it's still ON.
If you are getting 240 volts at the timer from the breaker, and if you can also manually turn the clock dial, then the timer motor is bad.
Dec 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
T104R timer clock has stopped working. I have to manually turn pump on and off.
If you can also turn the pump on and off manually by turning the dial, then the timer motor is bad.
Dec 02, 2009 | Intermatic T104R 208-277Volt 40-amp Timer...
Intermatic T104R 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw Logo
554 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
