Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer screen shows 8.8. when I go to dry a load of clothes and won't work
When went to dry a load of clothes this morning my Neptune dryer would not work. The screen said 8.8. It has done this before, but all I had to do was wait a few minutes for the screen to go blank, then start over again, usually trying a timed setting instead of the sensor setting. So far it's been several hours and the screen has not gone blank. I even turned off the electricity to it, but when I turned the eletricity back on, the 8.8. was still there. Help!
  • CallieDuncan Jan 20, 2008
    Thank-you, thank-you, thank-you! I tried the blow dryer and after a few minutes (just when I was wondering how long I should continue), it worked. The 8.8. disappeared and the control panel was back to normal. This has happened several times in the past, but I hadn't realized that it was always happening in the cold weather. We did have a high here yesterday of 11 degrees and today is not much warmer, maybe 14 degrees. My dryer is also on the main floor, but against an outside wall. Again, I say thanks!
I had the same problem this morning - my dryer would not work, the control panel displayed "8.8.". It was 18 degrees outside. Although my dryer is in main level of the house, it is on the outside wall, and I guess too cold to start. I tried turning off the power to reset the dryer, but that did not work. So, I read this blog...put a heater in the room, and also used a hair dryer on the contorl panel - within minutes my dryer was working. Thanks to all who provided solutions.
Posted on Jan 20, 2008
We had the same problem - you might try and hit the panel with a blow dryer to heat it up if it's in a cold garage - it may buy you some more time - It took mine 2 yrs to go out completely - when it finally did - I took out the curcuit board and found dark discoloration around the cluster of four resistors - after reading dozens of posts from multiple sites, decided to replace those four resistors and the three main capacitors in the same area just to cover all bases. And for only a few bucks - it works like new again!!! A service call could cost you @$300 - $500 from what other are saying! eek if that's really the case!
6ya staff
SOURCE:
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I blew a fuse last night and had to reset the breaker....I went to dry clothes this morning and the dryer is dead, wont come back on after being plugged and unplugged. I reset the circuit breaker too and...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune clothes dryer and have had it for years with no problem, love my dryer!!! However, this morning I tried to dry some towels and a code 8.8. displays on the display screen.. Please...
There is a technical sheet inside your dryer's cabinet. You can usually find it by accessing the rear of your dryer. All the fault codes should be explained in this paperwork.
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag dryer is not staying hot to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
Neptune MDG5500AW Gas Dryer: What causes my dryer to dry clothes one cycle but ...
Believe it or not your ignitor is going bad...
heatman101
May 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Neptune Dryer
the belt needs to be replaced. open the front of the dryer, remove the bulkhead and install belt. or call your service guy and have him do it
Sep 04, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
