Question about Epson Stylus Photo R220 InkJet Printer
It prints beautifully on plain paper BUT it does not always accept card stock 110. What am I doing wrong? Sometimes I get a single print then I get a message ''paper jam'' and then it just does not grab the paper.I am using the setting - letter size, default. Can you help me? Thanks, Liz P.S. Sorry, I don't have Facebook.
I hope someone answers because I have the same problem ...
Posted on Dec 22, 2009
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
The printer wont print on heavy paper is there a special setting i need to do
Paper types you can use:
Plain paper - 20 to 24 lb / 75 to 90 gsm
Photo paper - 6.5 to 12 mils (up to 290 gsm)
Card stock - 110 lb / 200 gsm, max
Envelopes - 20 to 24 lb / 75 to 90 gsm
Transparencies - inkjet variety with white stripe
Labels - all commercially available inkjet varieties on 8.5 x 11-in. or A4 sheets
There is no setting to allow printing of thicker paper stock.
For more information on your printer, please see the ESP 7250 All-in-One Printer Knowledge Center:
http://wwwcaen.kodak.com/global/en/service/products/ekn036791.jhtml?pq-path=2300285
Dec 20, 2010 | Kodak ESP 7250 All-in-One InkJet Printer
When i use card stock it acts like a paper jam,with a little help it prints fine
Make sure that you are setting the proper paper type before printing any paper other than "plain" by going into the printer's "properties/preferences". If it's thick paper, choose "thick" or "heavy" or "cardstock" in the drop-down arrow.
Unless, of course, your printer doesn't accept cardstock at all, then you're out of luck.
Hope this helps. :)
Sep 29, 2010 | Dell Office Equipment & Supplies
Printer streaks on card stock
adjust your thickness guage as card stock is 3 or 4 times thicker than a 20lb plain paper stock. Here is link to a helpful media guide for HP printers.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
Jan 30, 2010 | HP Color LaserJet 2600n Printer
HP Photosmart C4795. Can't get business cards to align correctly at top. Alignment is perfect on plain paper, but starts too high on card stock so every one is lined up wrong. What am I doing wrong? Using...
In printing properties and printing preferences be sure and tell the printer you're printing labels, it allows more time for the card stock to reach the starting point.
Jan 05, 2010 | Office Equipment & Supplies
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
Only prints business cards correctly on plain paper, but not on the card stock.
I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
Oct 21, 2007 | HP PSC 1410v All-in-One Printer
Epson Stylus Photo R220 InkJet Printer Logo
66 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
