Question about Sony KP43T75GRAY 43" Rear Projection Television
The flash focus does not align - Sony KP43T75GRAY 43" Rear Projection Television
  • 10,594 Answers
Flash Focus does not work when convergence out chip got defective, replacement of convergence out chip will solve your TV flash focus picture and will align colors.
Question post shows it is Sony KP-43T75 rear projection TV that has STK394-160 IC (two ICs) as convergence out chip that is available in Part Store for $36
Let me know if you want to repair TV by yourself to provide you more technical info, please note that above chips replacement in circuit board requires soldering work with proper tools. Or call local TV tech to fix it.
Thanks.
Posted on Dec 10, 2009
SOURCE:
How do i fix a color alignment problem?
Tries push the button said FLASH FOCUS or manual + - convergence alignment adjustment?Yes,n o,used?The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv have a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too on the convergence board,must replaced these parts to fix it.To solved tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 27, 2011 | Hitachi 46F500 46" Rear Projection...
I have a 2001 sony kp61hs30 that has always worked great. turned it on today, the blue and red do not match up. the flash focus button on the TV will not align the blue and red plus signs. Got any...
I have a 2002 sony KP61HS30 and the blue and red do not match up. I use the flash focus button and it does not align the red and blue plus sign. Have any suggestions?
Dec 11, 2010 | Sony KP-61HS30 TV
How do you manually set the convergence on a Sony KDF-60XS955
lcd projection sets don't need a flash focus ...there is no convergence alignment. replacing the optical block should be all you need to do. the block contains the lcd panels with the picture already aligned.
Jul 09, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Colors are not aligned
Can't use the flash focus button or the convergence control crosses +s don't alignes red,blue,green colors.The tv have convergence problems,it dead.Must replaced 2 STK convergence ICS,and some or all it resistors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Hue wont align and causes ghosting
you need to replace the convergence ICs and pico fuses. The KP46WT510 convergence repair kit at the following link works for your model as well and the kit comes with instructions on how to do the repair. Its listed under the convergence repair kit category.
http://servicemanuals.vstore.ca/
Feb 15, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen Is Blurred
Did you try hitting the small button on the front of the tv labled flash focus? Try pushing this button because this model only features auto focus for aligning the red/green/blue projectors.
Nov 24, 2008 | Sony KP-53HS10 TV
I can turn my camera on then the screen picture is all blurry and it won't do anything if you press the button as if to take the picture. The one thing i have noticed different is the letters [CAF] in the...
When the camera is set to C-AF (Continuous Auto Focus) mode the focus is continually aligned according to movement of subject or the camera even when shutter button is not pressed. The Continuous Auto Focus (C-AF) is disabled while the camera is zooming in and out. Once the camera stops zooming the CAF is initiated and the cameras focus is adjusted.
This is actually used for video.
Jun 06, 2008 | Samsung Cameras
COLOR LAMP ALIGNMENT
Needs convergence circuit repair...........
Requires replacement of soldered-in parts..............T.
Please rate this solution.......................
Sep 24, 2007 | Sony KP-53HS10 TV
Camera error
The problem is the internal focus lens is either stuck, or knocked out of alignment. The lens will need to be serviced, or replaced with a new (not cost effective), or good used lens assembly.
Aug 07, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony KP43T75GRAY 43" Rear Projection Television Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
