Question about AudioControl KVT-911DVD Car Video Player
Kvt-911 dvd red light blinkingfast, wont turn on and screen won't come out
Whats the unlock code fr the kenwood kvt 911 excelon
You will need to visit an Authorized Dealer or service center for that product to get the unlock code reset. You can find a dealer listing on their website, or call them.
Jan 07, 2011 | Kenwood Excelon KVT-915DVD Car DVD Player
Kenwood kvt 715dvd wont turn on
check all your fuses. check power for the battery(yellow) wire and red wire(ignition- key must be on), and if all of those are good then check the fuse on the back of the stereo itself, i think it has a 15amp mini fuse in it.
Aug 05, 2010 | Kenwood KVT-715DVD Car DVD Player
Cannot select play movie with dvd in
if im not mistaken that unit is equipped with "touch screen"... the only problem is on the older kenwoods you did need the remote to navigate the dvd... have you tried other dvds?
May 02, 2010 | Kenwood KVT-815 - 7" DVD/MP3/WMA Rcvr Car...
I can not watch the videos and movies in my Kenwood KVT 617 DVD
hi there
on the back of this unit is a green brake wire you need to buy a 3 pined toggle switch ...........you need to take a small but mid size length speaker wire and attach to 12v (red wire) going into back of kenwood unit add another speaker wire to the ground wire (black wire) of kenwood unit... now on the 3 pined toggle switch add the power speaker wire to the toggle switch add the ground speaker wire to the toggle switch once this is done add the green wire to the last toggle switch pin........put the kenwood unit back in dash.......now turn the car and toggle switch on...........put in a DVD and if screen shows DVD all is done...... but if the screen does not show the DVD......just switch the green wire with the black wire on the toggle switch and now it should work
hope this helps
Mar 02, 2009 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT911
kvt 911 screen does not pop up you have to manually flip it once it's deployed out.
Aug 28, 2008 | Car Audio & Video
About kvt 915
Unfortunately the brain and wires for KVT911DVD aren't compatibles with the KVT915DVD,but you may find them at ebay.com
If you find the brain by it selft you can order the cables from pacparts.com
Feb 09, 2008 | Kenwood Excelon KVT-915DVD Car DVD Player
Kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Dec 09, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt-815 dvd
hi bought a kvt-815 dvd player via gumtree was told needed a ribbon,,did have screen in pic but wont do anything at all no power all cables tested working can any one help...
Oct 26, 2007 | Car Audio & Video
No power
Have you checked the voltage to the harness yet?
Sep 22, 2007 | Kenwood Excelon KVT-915DVD Car DVD Player
AudioControl KVT-911DVD Car Video Player Logo
99 people viewed this question
Top AudioControl Car Audio & Video Experts
xxxxxx xxx
Are you an AudioControl Car Audio and Video Expert? Answer questions, earn points and help others
