Question about Coby TFTV1503 15 in. LCD Television
Coby 15" LCD tv is brand new and autoscan does not work - no channels available.
Return it....defective
Posted on Jan 03, 2010
SOURCE:
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
TV will not scroll through the channels. I have to enter each channel manually
If you have a cable box from the cable company you may have to autoscan the channels first look in the instruction book for autoscan channels
Jul 07, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
The problem with the tv is that it is no longer able to be turned on. i have tried many different outlets and that is clearly not the problem. also, the power system that came with the tv still has a green...
Hello
Connect the TV to external antenna or cable and do the following ot autoscan channels. If it autoscans, and doesn't store any stations in its memory, the memory IC has damaged and should be replaced with same type and number. Wait till autoscan completes and see whether the first channel receve will comes displayed or not. It will take some time to complete. the procedure is:
From Menu Press Vol [+/-] then Channel [UP/DOWN] buttons to find CHANNEL AUTOSCAN.
Press Volume [+/-] button, channels will be scaned automatically. OK
Jan 11, 2011 | Audiovox FPE1505 15" LCD TV Television
Carnt get any dtv channels up
Things to check: 1.DTV is available through your aerial. 2.You are on the correct setting on the tv (DTV) 3.You have run an autoscan to search for channels.
Jul 19, 2010 | Dell W3706MC 37 in. LCD HDTV
Vizio lcd retained channel info from former location
You will have to let the TV autoscan or autoprogram for channels again to fix this issue.
Aug 14, 2009 | Vizio VW32L 32 in. LCD HDTV
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
  • 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
  • Standard 4:3 aspect ratio, native 1,024 x 768 resolution
  • Plays DVD, CD and recordable MP3 music CD-R/CD-RW
  • Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
  • Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
  • Brand Name: Coby
  • Model: TFDVD-1540
  • Display Technology: TFT active matrix
  • Display Size: 15 inches
  • Image Aspect Ratio: 4:3
  • is_hdtv_compatible: N
  • speakers_included_description: 2 speakers
May 13, 2009 | Coby TF-DVD1540 15 in. TV/DVD Combo
COBY TV TF-TV1514 15'' TFT LCD TV
Go into your menu and navigate to find Closed Caption then turn it off. That should do it!!!! Read your manual also, it's possible you might have POP picture in which it displays multiple channels when you change it. That feature should also be in your manual.
Feb 18, 2009 | Coby TF-TV1514 15 in. LCD TV
Remote control set up /
you likely need to go into the menu and set it for cable then autoscan the channels to have them stored so you can switch through them.
Feb 17, 2008 | Televison & Video
Coby TFTV1503 15 in. LCD Television Logo
71 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
