Question about Google Chrome
Windows vista sp2, chrome freezes after about 10-15 min of use, not even the three figure salute helps (crtl-alt-del) have to force a hard shutdown, did have an issue w/ the sp2 install, it was cancelled during the install that killed all the sys restore points & also caused some startup issues that have been resolved. can i repair chrome or do i need to reinstall, i backed up the bookmarks any thing else i need to do for a reinstall?? TIA
  • 2,841 Answers
Download and install this fantastic free program CCleaner. http://www.ccleaner.com/download During the installation watch for the download of the Yahoo Toolbar and uncheck that box to prevent that from being installed. Now open CCleaner and go to the Tools tab >> Uninstall tab and uninstall Google Chrome. Now go the the Issues tab and scan for issues. Fix all issues it finds and make a backup if you wish, although I have never seen CCleaner cause any problems. It is a mild, safe, registry cleaner and will find many issues if you have not ran a registry cleaner before. Now go to the Cleaner tab and run the cleaner which will remove all temporary internet files and files you no longer need. Close CCleaner and open Disk Cleanup and run that. Remove all it finds. Restart your computer and install Google Chrome again.
Posted on Dec 10, 2009
Reset button acer laptop
Laptops do not have reset buttons ! If your laptop is frozen and won't respond hold down the power button for about 20 seconds and force it to shut down. Only do this if you have no other alternative as it is not good for the hard drive of the laptop. Try the three finger salute first CTRL- ALT - DEL and select task manager if windows system and see if any processes or applications have frozen and close them then select shutdown from the task manager if it is not frozen up.
Jun 23, 2014 | Computers & Internet
How do i get my laptop screen thr right way up i pressed somthing and its gone upside down
You probably flipped the screen orientation (rotated it).
For some versions of Windows (XP and Vista), try pressing Control (Crtl)+Alt+Up arrow (press the three keys together). You can also try the other arrow keys with the Crtl+Alt keys. The Crtl and alt keys are both usually in the row with the space bar. On a full-size keyboard, there are two Ctrl keys on the ends of the row and the alt keys are closest to the space bar.
Otherwise, right click on the Desktop (where there are no programs or icons) and choose Graphics Options > Rotation. Another place to check is right click on the desktop and choose Screen Resolution > Orientation. This is a shortcut to accessing the display properties in the Control Panel. Click Start > Control Panel > Appearance and Personalization > Display > Screen Resolution. For a widescreen monitor, choose Landscape.
I hope this helps.
(The ctrl+alt+arrow key doesn't work on my Win7 desktop but does work on the laptop. The Orientation change from the control panel works on both.)
May 04, 2012 | Acer Computers & Internet
Not shut down my computer
Is the laptop still operating?
If so press Crtl + Alt + Del to bring up the Task Manager then select Shutdown.
If not just press and hold down the Power button until the laptop shuts down.
Aug 05, 2010 | Dell Latitude C640 Notebook
REBOOT MY PC WITH WINDOWS XP SP2
Using your left mouse button click on START in the bottom left-hand corner of the screen then click shutdown, then select reboot.
Alternatively hold down the crtl and alt key and with them held press the delete key, then select shutdown/reboot.
May 06, 2010 | Toshiba Satellite A15-S127 Notebook
System Restore
Depending on system restore i.e. are you restoring from a previous driver restore point or a service pack restore point, it can take 20 minutes to 2 hours.
Jan 02, 2010 | Sony VAIO Notebook
Windows XP won't load - black screen
Refresh all the connection on your motherboard like ATX power supply, HDD and CD/DVD ROM cables, and specially the RAM. You may have to clean the RAM as shown in the image below. c4d62f6.jpg
then hopefully your computer will return to normal. Hope this helps.
Sep 24, 2009 | Dell OptiPlex GX280 PC Desktop
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
Where is the taskman located?
Right Click on taskbar.
The following keystrokes launches Windows Taskbar
CTRL + SHIFT + ESC
and
CTRL + ALT + DEL
The taskbar executable file is located in "C:\WINDOWS\system32"
Filename: "taskmgr.exe"
Hope this is what you've been looking for.
Nov 17, 2008 | Compaq Presario Notebook
Task Manager
Yes, this can be cause by a virus or just some prolem with the computer settings you can follow the step by step way from this two links in solving this problem
http://www.pchell.com/support/taskmanagerdisabled.shtml
http://ask-leo.com/why_is_my_task_manager_disabled_and_how_do_i_fix_it.html
Hope that helps.......
Sep 26, 2008 | Microsoft Windows Xp Home Edition Sp2...
Google Chrome Logo
715 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Peter Dragonetti
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
