Question about HP nx9420 Notebook
Two NX9420's, one boots fast, other doesn't (same drive)
I've got two NX9420's, and I would like to move the same drive between the two machines. However, one machine seems to boot right up, while the other takes 2min 15sec. If it's the "same" machine, why the difference in time to boot up? Even though the machines are the same, are they THAT different? And what can I do to make it boot faster, if anything.
    Sniper:
  • 65 Answers
Things to check.
1. amount of ram in each system.
2. msconfig you can optimize the system by turning off items in start up that aren't necessary. I.E adobe, AIM, etc if you are unsure then do google research or don't remove.
3. go to my computer: properties: advanced: visual settings: then uncheck every box besides the last four.
4. run malwarebytes (free download) to make sure the system isn't infected.
just a few tips that often help optimize. hope that helps.
Posted on Dec 10, 2009
    Guru:
  • 597 Answers
You need to check the bios settings. If for instance the first boot device on one computer is the harddrive and the second is the cdrom it won't take time to check the cdrom for a bootable disk and just start booting. If the second machine boots CD first then it will always check to see if a bootable cd is in the drive. There are many other options in the bios that can contribute to this. the clock cycles may be configure to overclock CPU, there are reset configuration option, is S.M.A.R.T. option enabled for one drive and not the other. You are dealing with a mass produced product also. There is the possibility that the ram may be different speed. You might try running some benchmark programs on the two laptops. There is also a program called SIW (System Information for Windows. It can give you a rundown of your installed hardware to compare them. Sysoft Sandra is a benchmark utility you can try.
http://www.sisoftware.co.uk/index.html?dir=news&location=2009_release&langx=en&a=
SOURCE:
The receiver for my wireless mouse just suddenly started freezing my Vista machine from booting. Just a blank screen with cursor flashing. But if I remove it before booting, it boots fast, then plug i
Try looking for a "patch" on the manufacturers website. You did not supply the Make, model of your machine.Are your windows vista updates current?
Nov 18, 2012 | Computers & Internet
I have a 1994 Polaris SL750 jetski. It revs up but often will not move thru the water very fast, it seems something is slipping in the drivetrain. I've pulled the shaft out - no cavitation, all
Impeller is most probably bent. It looks fine but there is a blade bent. Or there is a piece of wood or rock blocking the pump. Doesn't take much.
Jun 25, 2012 | Boating
How will i make my 2go star boost fast
if you are looking for a faster windows boot and operation your best bet would be to upgrade your harddrive to SSD(Solid state drive) super fast, windows boots in a matter of seconds...
but give this site a read...
http://howto.cnet.com/8301-11310_39-57363586-285/how-to-start-windows-7-faster/
success
Jun 19, 2012 | Acer Aspire 5920 AS5920 Notebook
The computer will boot up randomly with no assistance. Also doesn't boot right into Windows (must hit F1).
Could be a feature in the bios or a virus. I would do some research on the matter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Nov 11, 2011 | Dell Inspiron 530s Desktop Computer...
My machine is too fast, i've tried gently pressing on the pedal, I've even opened it up and tried gently sliding the activator along but this doesn't help, it still seems to just hit top...
According to the manual, there is no speed control on your machine. It is apparently built into the foot control unit. I suspect something is haywire with the foot controller but would suggest taking the machine and foot control unit to a sewing repair service.
Mar 07, 2018 | Brother XL-2600I
My laptop wnt boot up no matter safe mode or the other start menu's what am i to do
Do you have an external CD or DVD drive to plug into it? If so, and if you have a Windows installation disk, you can boot from the disk and do a chkdsk scan on the drive to make sure the drive doesn't have errors. If the drive doesn't have errors, you'll need to do a rebuild of the operating system.
If the drive did have errors and chkdsk says it fixed them, try booting into windows again.
If it still won't boot, do the OS rebuild.
If it reports there is no hard drive, you've got bigger issues and will need to have the unit repaired.
Jul 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
Notebook won't start after a bios flash was interrupted, caps lock keeps flashing when starting the pc. Is there perhaps a recovery jumper on the motherboard ? If so, where to find it ?
I've you interrupt a BIOS update, its broken.
You can try to reset the BIOS.
CLICK HERE
I've this didnt work, you need the BIOS to be replaced by a new one.
Jun 21, 2011 | HP nx9420 Notebook
HP NOTEBOOK WON'T BOOT UP...JUST CLICKING SOUND AND NON SYSTEM DISCK ERROR
These are typical symptoms that your notebook has a failed hard disk drive.
Apr 25, 2010 | HP Compaq nx9420 Notebook
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
HP nx9420 Notebook Logo
97 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
