Question about Roper MHE14XKB Microwave Oven
Microwave making strange noises and popping sounds when cooking food
Microwave is a Roper MHE 14 XMB-1 Serial Number TR R 51 41148
950W over the range microwave. It recently started making weird noises but still works.
Any ideas why, and home to fix it?
  • 8795 Answers
SOURCE: I need to buy a new microwave.
Can't the old one be fixed? I personally like Sharp the very best due to great service info availability and very reasonable part prices for the most part. Despite decent avilability of basic service info, GEs part prices can be beyond sky high. But I'd have to say I dislike Whirlpool most because of serious shortcomings in both departments. These are my professional and personal opinions.
Posted on Jan 15, 2007
SOURCE: GE Spacemaker XL1800
check conrol circuit, and magnetron, and highvoltage section,
Posted on Nov 04, 2007
  • 8795 Answers
SOURCE: Plastice door covering and handle
htmYou can usually find helpful exploded view diagrams and order parts by entering your full model number here.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
  • 8795 Answers
SOURCE: microwave oven not working
That model number looks a bit off. I'd say it's one of these:
But for a part like this, any of the above should be the same.
There are two oven cavity thermostats in this model, which essentially act as flame sensors.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here. (Try searching without suffix if you get no hits).
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Roper / Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jun 30, 2009
  • 22 Answers
SOURCE: my microwave make strange noise when plug in power
remove it from your home and buy another one they do have a small amount of radiation per unit its not worth it.
Posted on Aug 09, 2009
SOURCE: I have a Roper Microwave mounted over my gas stove
Usually you should have at least 12" - 18" AND a fireproof "Barrier" as the "Roof" of the stove "Floor" of the microwave shelf.
Posted on Jan 21, 2010
0 characters
1 Points
Glass tray turntable makes noises when heating food
Hi, the rollers on the support mechanism has residue, try cleaning the rollers and the track it follows, should resolve the sound problem
Jan 05, 2015 | LG LMH2016ST 2.0 cu. ft. Over-the-Range...
The oven has trouble ligting,and make,s a boom sound when lighting
If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Enter your model number to see parts for your microwave.
Help me find my model number
Exhaust Fan Motor
If the microwave is loud when running the fan motor might be
Stirrer Motor
If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor
If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Apr 02, 2013 | Microwave Ovens
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
I have a Roper over the range microwave and the unit popped while heating some food and I lost all power. The breaker is not thrown and the wall outlet is working?
It is more than a fuse, the magnetron has probably failed. When that pop sound is heard it is usually the above mentioned part which is the heart of the microwave oven.
May 01, 2012 | Microwave Ovens
Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
Blue goo is oozing from my Amana microwave from the plastic plug
As long as it is not interfering with the cooking of the food, and isn't dripping into the food itself, I wouldn't worry about it. Sounds like some type of sealant or perhaps plastic that is/was wrapped around a transformer that has gotten a little too hot. If the oven does go bad, it will probably be all of a sudden, and there will be an accompanying pop or loud noise. For now, cook on!
Of course, the standard disclaimers apply, and your mileage may vary.
Mar 16, 2009 | Microwave Ovens
Microwave heating problems
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
Oct 03, 2008 | Whirlpool Microwave Ovens
GE Spacemaker making odd noise
We are having the same problem with our XL1400. I suspect it has something to do with the turn table but don't know for sure. We would be willing to disconnect the turn table...anything to stop the noise but don't know how.
Mar 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Noise/humming while cooking; especially popcorn; intermitent on other food
Popcorn is heated by a metallic insert in the bag. This causes some additional power consumption by the magnetron. It is no cause for alarm.
Dec 19, 2007 | Kenmore 80412 Microwave Oven
Roper MHE14XKB Microwave Oven Logo
773 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
