Question about Western Digital Computers & Internet
Way to retrieve files off an ext. hard drive gone bad?
Seems my 300gb ext drive has packed it in. is there any way to retrieve my files? the drive starts up, makes a powering up sound, hear the disc search for a few seconds, then it repeats. Computer ( pc ) doesnt recognize it anymore.
Try to install the drive as a secondary drive in a pc u know works (dont mix fat with ntfs drives) if there both the same OS u should be fine, see if u can access the files then, if u can great pull off what u want to keep & reformat the drive, if u cant well..........read this, i couldnt explain it any better
http://www.popularmechanics.com/technology/how_to/4294038.html
Posted on Dec 10, 2009
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
Would like to erase 150gb maxtor external drive and start over
Connect the drive.
Open "My Computer".
Right-mouse click on the icon for the Maxtor.
Click FORMAT.
Choose Quick-Format.
When it completes (in a few seconds), all the files on the disk will be "gone",
because a "blank" Table-Of-Contents has replaced the previous Table-Of-Contents.
Dec 20, 2010 | Maxtor OneTouch II external hard drive...
My hard drive has lost alot of file from my hard drive however the space left on my hard drive hasnt gone down any. as well as this other folders have been appearing, usually with jibberish names, yet im...
Hello.... Hard time with your hard drive... Your hard drive need to be re formated (cause bad sector) due to corrupting file in your hard drive... You may have to save the rest of your programs and files
in another Hard drive then fix this one., a good program for that partition magic is the best.. Download it from the net for free..
then follow the instruction... good luck
Oct 20, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
My 300GB simple drive external hard drive shows up on my mac, and all the files are there, but it won't let me write to it any more. It is nowhere near full, and I have written to it before. I can copy...
Blah, stupid question about this folder, of course you can't.
If you have such possibility. The easiest sollution and almost guarantee it will work.
Copy all files from this ext HDD on your local pc and just format this HDD using windows formatting tool (right click on this HDD in my computer -> Format...)
pick NTFS of course
Cheers,
Mike
Leave rate if I helped you, thanks!!
May 08, 2010 | SimpleTech Signature Mini 160GB External...
External Hard drive wont show files or name
Even though you may hear the motor turning in your external drive the drive may not be able to read the information on the platter(s) because the arm isn't working. This cannot be fixed; you'll have to buy another external drive.
There are services that can retrieve the data on the broken drive. Google "data recovery services" and prepare to spend big bucks.
Jul 09, 2009 | Western Digital Passport WDXML800UE...
Hard drive connects and then disconnects quickly
Sounds like a bad solder joint or break on the circuit board. If the data on it is important, you may need to use a data retrieval service.
Jan 18, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
How to retrieve backup to a reformatted hard drive
The Maxtor will have come with backup software. You need to install this software on your PC and search out the restore mode.
Apr 16, 2008 | Maxtor OneTouch II external hard drive...
I dropped it on a floor. Now it gives an alarm sound.
wow..you'll need to get a data recovery expert to 'snapshot' your drive to attempt to recover your data. I'd suggest that the 'drop' did a major mechanical deal, like a head impact crash. Not good. A local tech store/computer shop MIGHT have the tools to extract the data. Last time I checked, it runs from 100 to 300 bucks, depending on what kind of files are retrieved.
Feb 16, 2008 | LaCie BRICK (301063U) 300 GB Hard Drive
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Apr 15, 2017 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch II 300Gb can't recover data after a system restore
I had the same problem a few weeks ago.
The way I solved my problem was to make sure when I restored Windows to the default settings that I did it up to the same support packs and hot fixes then when backing up the system with the Maxtor HD. It took me many days to figure this out... was written it the Maxtor HD documentation and it works fine.
Hope this helps.
Chris
Jan 15, 2008 | Maxtor OneTouch II external hard drive...
Computers & Internet Logo
223 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
