Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Our eletric went off today and when it came back on we had a flashing green light. There is no picture and we can not get it to power up. Please Help!
    Genius:
  • 1,030 Answers
Did you unplug the set and let it sit awile then plug it up. when you plug it up the light flash then you push the button then nothing happen. does it turn on with remote. also push and hold menu button on front for 10 seconds. Try these things out first
Posted on Dec 10, 2009
SOURCE:
Flashing green led light in back of tower
hi, okay you got to be careful here, it's sounds like the power supply has called it a day, disconnect from the mains take the side panel off and get sniffling can you smell a burn smell , no , now pull the power leads from the hard disk and DVD drive if fitted now removing anything that could cause a short on the board , turn it on, do you get video display ?
Please be careful of static shock and mains shock so only look inside once it disconnected from the mains.
Keep me updated please.
Regards
Dec 21, 2012 | Computers & Internet
When i try to turn on my tv the green power light will flash for about a minute the it will turn of and go to red then try to turn back on automatically no picture will ever come up because the green light...
i had my tv on for about two and a half hours then it will shut of and the temp light will flash, I think its overheating but not sure if its the fan or color wheel or both, wtf can somebody please help?
Dec 26, 2010 | Samsung HL-T5076S 50 in. TV
Bestec atx 250 12z Power Supply - Community power went off today - machine was on when power went off, but now will not turn back on. Now Green light is flashing on back of power supply. Light...
Outages are frequenly accompanied by power surges. It sounds like your power supply got cooked and does not produce enough power to start your computer anymore.
They are inexpensive and are easily replaced. Take a couple of digital pictures of it in your case and then remove it.
Measure the dimensions and go find an ATX power supply that will fit. I recommend that you go up to at least 350 watts. Use your pictures to help you install the new power supply.
If this helps please vote for my solution.
Sep 21, 2010 | Computers & Internet
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Grey static then flashing button
Could be your flyback transformer or these caps 2200 mf16v 22035v 33035v. Check the caps for bulging.
Jul 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
