Question about Kenmore Elite HE4 Electric Dryer
My dryer is leaking water - Kenmore Elite HE4 Electric Dryer
    Scholar:
  • 68 Answers
You venting is most likely clogged or has a droop in it where moisture will pool up. check and clean you venting and this problem should go away
Levi
Lebarchrigen Appliance Repair
www.lartoday.com
Posted on Dec 10, 2009
Hi my miele condenser tumble dryer t294c has started leaking water from inside machine and leaking onto floor has anyone any sugestions of the problem I'm getting thanks
you should remove the cabinet then pour water in and jumper the door switch and run and check where and which hoses are leaking if any? check ur water pump for damage and leaks
Feb 28, 2015 | Miele Dryers
Dripping water in frigidare. Affinity dryer
I appreciate your post, Joe Ivey!
From the information you have provided your Frigidaire dryer is leaking water inside the tub when clothes are drying. It sounds like your water valve may be leaking. You may want to have a professional technician out to your home to properly diagnosis your dryer this will help to avoid any unnecessary part purchases or future issues. Hopefully this was helpful. -Matt
Jan 11, 2015 | Frigidaire Dryers
Leaking water
Make sure your vent tube on the dryer going outside is clean the entire length and the outside door/loovers are free
Apr 23, 2012 | LG DLG8388 Dryer
Water under and around dryer. Clothes dry but water on floor. The wash not leaking. I the vent and line are not clogged. What is causing the water under dry?
Unless the clothes are dripping, soaking, wet when they're put in the dryer (and it would take them a loooong time to dry if that were the case) there's bound to be a leak of some kind coming from somewhere other than the dryer. Do you have a lavatory or toilet on the other side of the wall behind the dryer? They dryer has no water of its own to leak.
Dec 27, 2011 | GE DBXR463EDWW Electric Dryer
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
My dryer is leaking water from the bottom of dryer
Check the vent coming out of the back of the dryer. Somewhere in the vent there is a blockage. If you clear the blockage you may solve the problem.
Jan 07, 2010 | Abbaka White Knight 44AW Electric Dryer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Water is coming out from under the dryer while drying clothes.
only one place water can come from a dryer area and that is if your vent duct comes out top of house or vent housing is pointed up and they catch water if it rains hard ,,, i would check my water for leaks or if you have a hot water tank close check it too ,,, water may be coming from washer and flowing down hill to under dryer and then running out ,,,, your dryer isn't leaking water i bet / larry
Dec 04, 2008 | Dryers
CONDENSER DRYER IS LEAKING WATER
make sure it is pushed all the way in but it could be something simple like when it was moved water has splashed out into the inside of your dryer which will make it look like it is leaking had same problems like that with other customers dryers leave it to run and more than likely that it will dry itself out
Dec 01, 2006 | Hotpoint TDC32 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
163 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
