All-pro 60,000 BTU multi-fuel
Wont start, powers on, spits a cloud of smoke and shuts off. I'm burning #2 diesel fuel, worked fine until last 2 times, particularly bad in sub-zero weather.
I have the exact same problem on same model.
Posted on Oct 11, 2009
  • 45 Answers
It looks like a blockage somewhere in the system, does it have a exhaust vent check its clear and also check the burner if its clear.
Posted on Jan 27, 2008
Clean or replace the filters and burner nozzle.
Posted on Nov 13, 2011
1991 Alfa Spider Veloce - Had stored car for about a year. Started and ran fine for about 2 miles. Got in the car 3 months later, car smokes, spits out fluid from exhaust. Am draining gas, but also...
Well, I can tell you that white smoke is usually a sign of water being burned in the cylinders and a blueish color smoke is usually a sign of oil being burned. I would drain gas, replace fuel filter, and do an oil/filter change as well but replacing the injectors probably won't do much for you. I would make that one of the last things to do. You may also want to add an additive to help "dry" the fuel system as well.
Dec 05, 2017 | 1991 Alfa Romeo Spider
My Dyna Glo heater forced air heater worked great last year. I run it on Diesel and ran it empty before putting it away for the summer. Went to fire it up and it wouldn't work. Replaced all of the cracked...
the filter in the tank line is partially clogged with gel from useing diesel fuel you should really use a anti gel agent when running a sulphur type fuel in a unit designed for white gas/ keosene
Jan 20, 2010 | Kitchen Ranges
Do i need to replace filter if i have been using kerosene and want to switch to diesel
No, the kerosene is number 1 fuel oil and Diesel is number 2. No.2 is a heavier fuel with more BTU's than the kerosene. After you have burned the diesel for awhile, you may want to change the filter. If you have trouble getting the diesel to burn, mix it with 25% kerosene and it will flow and go through the nozzle easier
Jan 04, 2010 | Reddy Heater 60,000 BTU Kerosene...
Reddy heater 60000 btu kerosine heater
it either has too much fuel or not enough air. you will have to adjust both to figure out which is the culprit
Dec 12, 2009 | Reddy Heater 60,000 BTU Kerosene...
Heater wont start.Fan goes, Starts to heat, then blows a couple clouds of smoke and dies. Ive cleaned filter, new fuel. Cant figure out what adjustment I should be doing. Glow Plug? What else?
take the shield off and see if it burns with more combustion air. If it does then the heater isnt getting enough air. look for a shutter or set screw near the burner that should be the primary air adjustment. sounds like you have been working on the fuel side already. You may check the orfice to see if it is partially blocked, use a safety pin and gently **** it out. also check the burner tube
Dec 07, 2009 | Reddy Heater 60,000 BTU Kerosene...
Ihave a R60A heater that when I turn it on it
This is in referance to the R60a 60,000 B.T.U. Multi fuel heater
Sounds like the your ignitor has burned out. Had the same problem. Now looking for a replacement. Checked mine and for some reason the filiment has broken/burned off. Ran across this on a search for one. Good luck!
Oct 11, 2009 | Reddy Heater RLP100 Portable Forced Air...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Jan 22, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
All pro multi fuel
This may sound dumb, but is it full? i have a simupar one and if i start it out at 1/4 tank or ness it will not run long before it shuts off.
Dec 12, 2007 | All-Pro Forced Air Kerosene Space Heater...
Heating & Cooling Logo
515 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
