Furnace not blowing hot air but cold, gurgling sound from the unit, likely condensation lines.
  • 43,501 Answers
It sounds like a vent pipe sagged or the condensate drain trap is plugged.
You did not say what make and model furnace you have so I'll have to give you some generic intructions.
(1) Find the condensate trap and pull a plastic hose off of it and blow it out as best you can. Also you can pull the bigger hose that most furnaces have at the bottom of the heat exchanger off and blow through it.
Check all of the hoses to make sure that they are not plugged or filled with water. Methodically go through each one carefully pulling and replaceing exactly where they came from. Do not just pull all the hoses and expect to remember where they came from.
(2) Check the intake and exhaust pipes, assuming that this is a two pipe furnace. If there is water build up in the exhaust pipes the furnace will not operate.
Check for places that the pipe could be sagged or trapped. Even a sag will allow enough water to pool in the pipe and stop it.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 10, 2009
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
I went downstairs to start a load of clothes and noticed water under my furnace. My A/C is running and I had it cleaned a few weeks ago and the unit itself had to be charged. It has run beautifully and...
Hello, most likey if the unit is cooling and there is no visible ice on the suction line then it is probably a cloged condensate line that will need to be cleaned.
Jul 11, 2011 | Heating & Cooling
Just cut on 8 year old Goodman CPLE24-1 AC for the summer. Ran 8 hours fine, Next morning noticed outside unit running, very little cool air blowing out of inside floor vents (like the blower fan was...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Apr 12, 2011 | Goodman CPLE24-1 Air Conditioner
The air conditioner will work for a while but then shut down by itself.
Please read the above paragraph and see if we can narrow the possibilities. How long does it stay off? Does it restart by itself? Does it blow any cold air while running? Thank you. Roger
Apr 11, 2011 | Sharp AF-S100MX Thru-Wall/Window Air...
Unit only stays on for a couple of minutes before shutting off
Does this help to narrow it down for me? How long does it run? How do you restart it? Roger
Apr 11, 2011 | LG LS-K1830CL Cool Mini Split Air...
Hi- how do i add refrigerant to a rheem classic super quiet 80?
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know. Roger
There are service ports on the ends of the two copper lines at the condenser. Be VERY careful not to get any air in the system. Air carries moisure which will create acid and destroy the system. Don't touch the the smaller line. Pressure there is usually over 200 PSI. You sound like you have done this before. If not, let me know. Roger
Apr 10, 2011 | Heating & Cooling
PA10JA048-H Payne Air Conditioner outside unit not working but is getting power from circuit breakers. Need help.
Please read through the following and see if you can pin point the problem. Write back if you need with more information and I'll walk you through what ever you find. Roger
The ac is a window unit its blowing air out strongly but the air coming out is not cold
Make sure the condenser fan is running. That is the one that blows hot air outside. Also see if you can tell if the compressor is running. There is a discharge line and a suction line on the compressor. The suction line should feel cold and the discharge line will be very hot. If the condenser fan and compressor are both running then you may need to get the refrigerant charge checked.
Jun 04, 2010 | Kenmore Heating & Cooling
Bubbling water sound in AC. Water in the tray is cold. Unit continues to make a gurgling sound.
The gurgling sound is the liquid refrigerant going through the refrigeration copper lines , it's normal. And the water in the tray is condensation and is cold because is from the circulating air that gets cold going through the air handler(inside unit) You only has to keep the drain clean ,by pouring 1/2 cup of clorox every 3 or 4 months.
Sep 25, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
679 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
