Question about ViewSonic Graphic VG2021m LCD Monitor
VG2021 monitor. been fine in past, now black intermittantly
Have a VG2021 monitor. Has been fine. In past month, it intermittantly refuses to light up even though the blue light is on. I almost did not get it to function today. What is wrong and what is the solution? When it's on, there is no complaint. I have checked all of the connections and they are tight.
Thanks
    Problem Solver:
  • 11 Answers
I've repaired two of these, so far, by replacing the same two bulging electrolytic capacitors in each. If I recall, they're 220uF, 25V, radial. (Radio Shack has 35V capacitors that work just fine.)
Posted on Apr 14, 2012
  • 80 Answers
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Posted on May 15, 2010
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Dec 10, 2009
  • 732 Answers
Eyedocmel, It's not you! It's not the PC! It's the monitor's "switch-mode-power-supply"!!! This seems to be a black screen problem. Here is what could possibly be the problem and cause!!! If this monitor connects directly to an AC outlet without a "BLACK BRICK" between the outlet and back of monitor you have an INTERNAL "switch-mode-power-supply" that takes AC and converts to low voltage DC volts. (+5v or +3.3v and +12-to-+18vdc) The +12 is used to power-up another circuit called an "inverter" (electronic ballast) to light-up the 2 thin "cold-cathode-fluorescent-lamps" on rear of the lcd panel you look at!! Now if any of the components on the SMPS/inverter circuit board develop what is known as "thermally intermittant" connections at the place they are physically soldered to the circuit board you will possibly have your type of symptom until the solder joint becomes oxydized from the surrounding atmosphere. Then it won't turn on at all! The first place I would look would be the power devices in the inverter circuit. I use an old USN Bausch-Lomb inspection microscope to find these type of board FAULTS. Thermal intermittant connection is result of Thermal /Vibration Fracture occuring at site. Cold solder joints and T/Vfractures will need to be resoldered to correct problem. Also inspect SMPS for same and also for SWOLLEN electrolytic filter capacitors!!!!
Read some of my other responses here on fixya and do some research at Youtube for productive, informative video clips of "lcd monitor disassembly" and "lcd monitor repair" FYI !!! lmistyrel on aim.com or 12fixlouie on fixya. My recomendation is get new display AND repair the Viewsonic VG2021. Keep as spare or use at home. Read more of my responses to others with BLACK SCREEN to find out some other options not mentioned this post. You should be able to access my profile on fixya. Bye for now.
Why does my acer b243hl black out intermittently
Sounds like your power supply or board inside the monitor is bad....may need to be replaced.What kind of power supply is it...just a cord or box going to monitor?
Sep 04, 2014 | Acer Computers & Internet
Gradual diming of screen over the past month.
The speaker assmbly slide out, it has two fingers on it, see pictures here on what to look for inside: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | Dell E173FP 17" LCD Monitor
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Have 7200 GS PCI-E and after working fine for 18 months, am now getting flickering intermittent black horizontal lines on my lcd monitor. suspect the graphics card as monitor tested fine on another pc....
Take out the graphics card and clean the contacts on both sides (a rubber on the end of a pencil is good for this) and retry. If possible try the graphics card in another computer.
If all this fails - get a new card!
Nov 03, 2009 | Nvidia GeForce 7200 Graphic Card
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
I have a viewsonic vg2021, it was working perfectly now when i try and boot up computer it says analog - no signal then the light on the screen goes orange, Please can you asisst urgently...
Hi grazerone,
That typically happens when there is no video connection between the pc and the monitor. Are both sides plugged in?
Alternatively you may have put the interface cable into the wrong socket on the video card.
Regards,
Ebek
Dec 19, 2008 | Computers & Internet
Acer 22 inch monitor shuts off with indicator still green
The computer may be programmed to do a monitor shut off after lets say 20 minutes. This is a power saving feature of the operating system. Open Power Options under Control Panel.. select the drop down combo box that says "Turn off monitor" : set it to NEVER.
Nov 16, 2008 | Acer AL2216WBD LCD Monitor
Blank screen, led lights on, intermittent beeps
take out the RAM of your laptop, put it again,
also check the display on external monitor through vga port
Oct 20, 2008 | HP Compaq nc6000 Notebook
AOC 19MVWK - no image or rainbow vertical lines
It seams like connection is bad. If it is black but light show that is on or in stand by than it is the cable from monitor to computer if monitor is totally off when it is black either the electrical connection is bad or the power plug is broken.
Jan 31, 2008 | AOC 19LVWK LCD Monitor
ViewSonic Graphic VG2021m LCD Monitor Logo
429 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
