Question about Hotpoint HSS25GFP Side by Side Refrigerator
Clicking, no water or ice, power problem?
A few months ago, my HSS25GFPJWW started clicking and not dispensing water until after a delay. I changed the filter and it worked fine. Later it stopped dispensing, and I noticed that the light next to the dispenser would go dim when I got water or ice. I removed the light bulb and it worked fine again. Over the next several weeks, it would click even more, but every time I took off the front panel and made sure all the connections were tight, it would work again for a while. Now it's quit clicking and won't dispense water or even open the ice chute flap. I think it's not getting enough power, but what can I do about it?
    President:
  • 1,314 Answers
First i wold check the micro switch that the acuator paddle trips next i would replace the watervalves which is the most likely cause of this finally id replace the control bd as some early ges had a promblem with this there is also a solinoid in there for opening the ice chute door but that wouldnt affect the water but may cause a voltage drop if its getting bad id change the water valves the ice is on one valve the door water is on the other
Posted on Jan 19, 2008
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Side by Side Bad Water Taste
Most "new" fridges with water dispensers and ice instruct the consumer in there manuals to "bleed" the reservoir by running a couple of large pictures of water thru it. I usually recommend dumping the first few harvest's of ice as well (I believe this is also mentioned in most manuals too). once that is done the water should be fine as any contaminants in the system/reservoir should be gone. you may try changing the filter after this, but it shouldn't be necessary. most ice makers do not have there supply water travel thru the water dispenser reservoir however. the water filling the ice tray should have no baring on the water you dispense into a glass to consume.
hope that helps.
good luck
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
HotPoint fridge clicks and the fan doesn't turn
14 vac indicates a bad motherboard.Clicking could possibly be a bad start relay on the compressor.
Relays are inexpensive. I would replace the relay and hope for the best. Next step would be the motherboard that GE has had trouble with from day one
Jul 21, 2009 | GE Refrigerators
No water from the dispenser
You need to replace the dual solenoid one side is for the water the other is for the ice.
Jan 18, 2009 | Amana SXD524VW Side by Side Refrigerator
My GE Refrigerator Clicks for hours but will not start.
Clicking you describe sounds like a bad motherboard. Water dispenser issues have been result of frozen water in the tubing in the bottom of the FF area, which you should not have at the moment, so if it is not dispensing water now I'd check the water valve coil. (there are two coils on the inlet valve, one for the icemaker and one for the water dispenser.)
Sep 26, 2008 | GE GSL25JFR Brushed Steel Side by Side...
Ice Maker doesn't work
i press ice dispenser . and ice will not come out an light goses dimm please help
Sep 01, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
Clicking noise
THE FRONT PANEL IS DEFECTIVE. HAVE REPLACED TWO IN LAST MONTH. JUST TAKE NOTE OF MODEL WITH DEALER AS CERTAIN MODELS HAVE TO HAVE THE POWER BOARD REPLACED AS WELL.
Jul 07, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
335 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
