Question about Dell 5110cn Laser Printer
Install developer assembly for dell 5110cn
I just got a dell black developer assembly for a dell 5110cn but i have NO idea how to install it.
    Guru:
  • 73 Answers
Installing the Toner Cartridge
  1. Remove the top cover.
  1. Pull the toner seal for each toner cartridge straight up to remove it.
NOTICE: Pull the toner seal straight up. Pulling the toner seal diagonally may tear the seal.
3. Replace the top cover by inserting its front side into the printer first.
Installing the Imaging Drum install developer assembly for dell 5110cn - caution.gif CAUTION: Make sure nothing touches or scratches the surface of the light-sensitive drum surface (green-colored roller) or the transfer roller (black-colored roller). Scratches, dirt, or oil from your hands on the imaging drum or transfer roller may reduce the print quality.
  1. Push the front latch up and fully open the front cover.
  1. Push the button and open the top cover.
  2. Remove the protective cover from the imaging drum.
  3. Holding the imaging drum by the handle with the flat part facing the back of the printer, align the plastic guides on both sides of the imaging drum with the slots in front of the arrows on the printer. Gently lower the imaging drum into the printer.
    NOTICE: Lowering the cartridge into the printer without correctly aligning the rollers with the slots can damage the cartridge. NOTICE: Do not allow the surface covered with a protective sheet to come into contact with anything.
5. Pull the protective cover on the imaging drum straight up to remove it.
NOTICE: Do not touch the transfer roller (black-colored roller). Make sure that nothing touches or scratches the roller surface. Scratches or oil from your hands on the roller deteriorates print quality.
6. Close the top cover.
7. Close the front cover.
Hope this helps.
Have a good day.install developer assembly for dell 5110cn - owners_45_01.gif/a> owners_45_01.gif
Posted on Dec 10, 2009
My dell printer 5100cn , print quality very light, replaced inks drum and still having problem with black
laser printers have a high freq high voltage wire that puts ions on the paper as it passes ,
have you cleaned this wire . it attracts dirt an inks like the paper it treats.
there is a wire cleaning tool in the machine usually.
Jan 04, 2015 | Dell 5100cn Laser Printer
Colours are faded despite all toners at 25% or
If there is black "dust" all over the developer (behind the image drum assembly ) you need to replace the developer; that is uncoated toner prevenitng transference of colored toner.
Jul 30, 2010 | Dell 5110cn Laser Printer
DELL 5110CN PRINTS PRINTS LIGHT GRAY NOT BLACK!
try to print test page and determinate which or colour is fainting. if it is one colour then you need to replace this colour image drum. If all of colors is fainting then its transfer roller.
Dec 29, 2009 | Dell 5110cn Laser Printer
My Dell 5110CN printer is printing a double image
I am having the same problem, and I am using the original toner cartridges that were supplied with the printer, so yes, they are genuine Dell toner cartridges.
Dec 27, 2009 | Dell 5110cn Laser Printer
Dell 5110cn
I had the same problem and Dell tech talked me through it. First, hit Menu key. Using up and down arrow keys, select Administrator. Then select Maintenance. Then select Clean Developer. Keep using down arrow keys to get to these menu items. Using down arrow, select color to clear (in my case magenta). Run this whole routine 4 times. It takes a while each time. What is going on is that in the center section of the printer, there is a roller with felt on it and it is cleaning the toner off of the developer roller (you can see all the toner on it if you take the assembly out). Print 10-12 copies of a blank document (e.g., in Word). Should clear up.
Dell thinks this happens if one has the printer plugged into a power bar or other bad electrical connection. We had a power outage but the problem happened suddenly from one print job to the next.
Oct 17, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Printer Problem
Hi Caroline,
Thank you for using Fixya.
From what you mentioned, it does sound like you may have a defective black developer, especially since the rest of the colors are still functional.
The imaging drum COULD cause this as well, even if the other colors are working, as the primary transfer still has involves a photo conductor that acts independent of the other 3 colors.
Before you swap out any parts, do try this... using the control panel, lets try to clean the black developer unit. what this does is cause the auger to move toner from the cartridge to the black developer and insures that there is in fact toner in the developer.
click on the menu button, scroll to select maintenance, then developer cleaning, then select black.
try printing again after that.
If that does not fix the issue, again before spending money on repairs, I would try a new ( or an old one if you did not get rid of it ) imaging drum. If that fixes the problem, then it needed to be changed. if it does not, it IS a consumable and will need to be changed in the future anyway, you can put the old one back in and the new one back in the silver pouch and reseal it until you need it.
if neither of those two things work, then the next step would be the developer itself.
I am sure you can purchase the item from Dell. I have not looked, but usually you can do a google and/or ebay search for any Dell part number as well and find it for sale that was as well.
Good Luck :)
Oct 12, 2008 | Dell 5110cn Laser Printer
looks like this is a duplicate post from the last one that I already replied to.
I will just continue to help on the other one .
Thanks,
Cory
Oct 12, 2008 | Dell 5100cn Laser Printer
Dell 5110cn Printer Printing Blue Shadows
I did the following and it has stopped printing "shadows". I don't know if it was one solution or the other (or both) that worked.
1.On the face of the printer press the "Menu" button>Admin Menu>Maintrnance>Color Reg Adj>
Auto Correct>Yes
2. "Menu" button>Admin Menu>Maintrnance>Clean Developer>(Pick problem color)>Yes.
Hope it helps
Aug 16, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Laser Printer Logo
505 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
