Question about GE (PSS26MSRSS) Side by Side Refrigerator
Our water dispenser stopped working we can hear it click but water will not come out?
  • GE Master
  • 1,606 Answers
At the bottom of the freezer door ( remove the kick plate by removing 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If frozen , GE has a water dispensor heater , pt # WR49X10173 , to keep this from happening again . Also , by turning the dispensor light on , for several hours , so it will heat the spout , has worked for several people .
Posted on Dec 10, 2009
Why doesn't my refrigerator water dispenser work?
Just like in the ice maker, you will find a solenoid valve.
If you hear the valve click open and close when trying the water.
If you do not here the valve open and close, check the switch and valve.
May 19, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working
Have you changed the water filter? they can plug up over time. The water tube can freeze in the door. To test this there usually is a disconnect under the freezer door side of the grill you can disconnect this and hit the water dispenser lever. If the door is getting water then it is frozen in the door. If not the water valve could be your problem there are two sides to the water valve one for the water dispenser and one for the icemaker. A last possibility is there is a water tank or tubing loop in the refrigerator behind the crisper this could have frozen.
Feb 10, 2014 | Refrigerators
My KitchenAid side by side refrigerator is just over six years old. The water dispenser just stopped working today for no apparent reason. I'm not sure there is new water for the ice maker. I can hear a...
That is the inlet water solenoid you hear click. The water maybe frozen somewhere in the hose. You can check for water getting through the solenoid valve by pulling the hose off going to the freezer and have someone push the dispense button while you hold a towel to catch the water coming out of the solenoid. If that works, then the hose is frozen or clogged.
Dec 10, 2013 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser ice maker
If you check the backside of your refrigerator...
There are TWO (2) different electric water-valves...
A generic WHIRLPOOL part number = wr57x10032
(typically you can hear the "THUMP" when the are working...
WATCH this attached video...
http://www.appliancepartspros.com/ge-water-inlet-valve-wr57x10032-ap3192626.html
Hope this is helpful...
Carnac the Magnificent
Dec 07, 2017 | General Electric GSH25JSXSS Stainless...
My water dispenser stopped working. When I try dispensing water, I hear a clicking sound, but no water comes out. Is something frozen inside? When this has happened in the past, I've emptied the ice...
That can only be a blockage from the valve or crimped water line or a defective solenoied on the dispenser side of the water control valve part number WR57X10032
Sea Breeze
Oct 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
The water dispenser on my beko ap930 has stopped working can anyone offer any help,the piping all seems to be ok,could it be the valve ?
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. If it's not and you can hear to valve click, there is a valve our water supply problem. If you don't hear the click, it's a dispenser switch problem. If it's normal, disconnect it at the bottom of the freezer door and try again. It it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 15, 2009 | Refrigerators
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice and water stopped dispensing
some models of this refrig have a lcok out feature on the dispenser look for a padlock symbol on the dispenser console and make sure its unlocked. if it s not locked out you may have a broken switch bracket behind the console cover. when you press the levers listen very closely and you should hear a click noise letting you know the dispenser switch has activated. Let me know if you have any further questions thanks Peyton
Mar 07, 2009 | Whirlpool GD5SHAX Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
514 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
