I tv works OK, however, it has a red area on the
My tv works OK, however, it has a red area on the right and blue appears across the face of the monitor.
hardrocko
  • 1476 Answers
SOURCE: Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Posted on Jun 22, 2006
SOURCE: RCA- R52WH74
I had the problem with my rca looking like it was in 3d. anyways, I read this post and ordered the part ($3.79). did the soldering and TV works perfect now. Txs so much for the info on how to fix the problem. I was so worried it was going to cost a ton to have someone repair the TV. Much appreciated!
Posted on Apr 20, 2008
  • 1030 Answers
SOURCE: Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Posted on Jun 21, 2008
  • 226 Answers
SOURCE: Gateway fpd1960 tft lcd monitor has blotchy color lines across screen.
You likely have a bad 'controller' board, the one that converts the analog monitor signal into Row and Column addresses to tell the screen which pixels to light up, and which color. You may have a loose connection where ribbon cables connect to the board or the LCD panel, but you'd have to take it apart to see.
Likely the monitor part would be prohibitively expensive when you add in labor costs. If I owned it, I'd take it apart a bit and check for loose things...
tom
Posted on Jan 04, 2009
  • 135 Answers
SOURCE: Blue haze/blob near the center and lower right corner.
Failing optical block. check this website
http://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement
Posted on Mar 08, 2010
Hello, I have a 42"
Sounds like a backlight is out. If its still under warranty, exchange it. First try unplugging it for two minutes to reset the t.v.
May 15, 2011 | LG 42LG30 42 in. LCD HDTV
Mar 08, 2010 | Sony KDF-E50A10 TV
I have a bush colour tv and there is a blue,green,red colour wash right across the picture so people''s faces look half blue,green red....sort of as if there is a rainbow across the screen.. i do not have...
It sounds like your TV may need degausing.
Is your TV situated near to any loudspeakers or other devices with large magnets inside them? Or has anyone been near your TV screen with a magnet???
You need to try to get the screen demagnetised (degaussed). Many TV engineers have a degausing coil that could do this. It only takes around 20 seconds at most.
Some TV's like Mitsubishi have a DG button on the remote, that does this function without the need to call out an engineer! It only needs one press of the button every few years!
Nov 17, 2009 | Televison & Video
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Blue hue with faces of people
u check rgb could be transistor at the tube there problem.1 is red ,2 is blue 3 is green and u check area blue transistor.or may be your board up there at the tube need to be solder back again ok.dry join..Be careful and make sure turn off the power switch before u do it.Only expert can do it.If u do not know how to read meters reading....ok
Apr 06, 2009 | InFocus ScreenPlay 4800 Multimedia...
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Toshiba colours gone wrong
Yes it is repairable. One of two things is wrong. The color wheel is going bad or the DMD board is going bad. These are the most common repairs needed for a Toshiba. I hope this will help.
Mar 23, 2008 | Televison & Video
Westinghouse 32in HDTV-Ready
I called westinghouse with a similar problem(my picture shows up but all the white turns blue or somtimes pink).
they say the problem is similar to that of the xbox 360's red ring of death problem. Now what needs to be done is the unit needs to be unplugged completely for about 30 minutes. this allows the unit to completely cool down. and when the unit restarts and heats up the troubled connections will reflow and all will be fixed.
I tried this and it worked well for my TV. but it is only a temp fix and will need to be done again if the problem occurs.
Oct 09, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
