Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca 52 inch d52w2o tv
There are 3 circuit boards i think they are connected to the bulbs in the front of the tv one of the boards have arked on the under side of a bourd where a barrel shaped part that says p7a on it this board got wet it looks like the solder is of the points and it arks if i re solder this will it fix the problem and help the tv work sorry for the loose lingo i dont know any thing about elecronics please help
  • shane12 Jan 20, 2008
    tvtek thank you for your help i should have said that the buard was wet from my dog wizing on it
  • 1,284 Answers
If one of the CRT boards is wet, then you have one of the 3 CRT's that is leaking cooling fluid and must be replaced. If the leaking CRT isn't replaced then you will have the issue repeat itself.
Posted on Jan 19, 2008
I get no picture from my rca 52 inch tv
Have you taken the back off to see what is visible to you ? it could be a high voltage transformer or bad connections on the bottom of the SMPS deflection board being the board on the left looking in to the back of set. or a you should be able to see something burnt or a smell of the area some times helps to locate what you don't notice .
but most likely the problem in on that circuit board .
Mar 04, 2015 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replace a projection bulb on a RCA D52W23?
I have this tv.
pull it out and start undoing the screws towards the bottom half of the tv around the back, get the speaker grille off and then in there is your access cover for your bulbs. theres three of them red blue green. the bulb assemblies and circuit boards are integrated 3 bulbs -three separate assemblies. you will probably have to turn the tv back on when its disassembled to see which bulb went.
Nov 12, 2010 | RCA D52W23 52" HDTV CRT TV
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
52 inch tv has a warped picture with a rainbow type ark at top
This set needs a major repair. there are bad connections on the power board and a fuse is blown. You pretty much need a technician to fix this.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch tv will not come on and has no sound
you can get your TVs deflection board remanufactured at the following link for alot less than that shop is saying and they guarantee the board for 6 full months.
Aug 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch TV (turn on problems and channels rolling) HELP!
Your set uses the 195 series chasis. The only thing I can think of which would make the channels scroll by themselves is a contaminated PC board and pushbuttons behind the buttons on the front of the set. This is usually the case when spray cleaner or some other fluid is sprayed or spilled on the screen, and it drips down onto that board. To prove this, remove the back cover and on the top of the main chassis, where the top of the picture tubes are, is a small PC board with the remote reciever and a couple of jacks. The smaller jack is for the speakers and the larger jack is for the front panel PC board. Unplug the larger connector which goes up to the front PC board and then turn the set on with the remote. If the set works normally, the front PC board will have to be removed and cleaned or repaired (or just leave the jack unplugged and work the TV from the remote only). If you do not have any experience working inside projection sets then allow a qualified tech to handle it for you.
Aug 30, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
263 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
