Question about Magic Chef Ovens
The electric ignition lights but the burner will not light.model number 31213WAV
    Scholar:
  • 68 Answers
If your talking about the oven not lighting then it means your bake ignitor is too weak to turn on the gas. part number 12400035
go to order part http://lartoday.com/order_parts.htm
levi
lebarchrigen appliance repair
www.lartoday.com
Posted on Dec 10, 2009
HOW DO I LIGHT OVEN PILOT?
Hi and welcome to FixYa, I am Kelly
Your model number was missing digits so I used this manual:
GRP17WEWWW
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981380002.PDF
and if your unit is older this one:
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=ShowPDF&FileName=49-8514.PDF
Automatic Ignition
The oven burner is lighted by electric ignition. To light the burner, press the pad for the desired electrical function and press the INCREASE or DECREASE pad until the desired temperature is displayed. The burner should ignite within 60 seconds. After the oven reaches the selected temperature, the oven burner cycles off completely, then on with a full flame to keep the oven temperature controlled.
GE contact data:
If you don't understand something or need more help, call:
GE Answer Center®
800.626.2000
24 hours a day, 7 days a week
Both the new and OLD units use a glow bar for lighting the burner. Most likely your Glow Bar has failed: GE PN: WB2X9154
The Glow Bar is item 316 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214914&diagram_id=20725728#d20725728
If you net search the WB ge part number you can save lots of money!!!!
http://www.amazon.com/WB2X9154-Gas-Range-Oven-Igniter/dp/B004H3XQPM
If the glow bar is glowing and you still do not get ignition respond here and we can go through troubleshooting.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | GE JGRP17 Gas Single Oven
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven with electric igniter won't light. stove burners work
Common problem, as the range gets older, the bake ignitor gets weak or fails completely. Order a new ignitor using your model number, but ask if they have a cheaper generic ignitor for your model. There can be another cause for this, however the ignitor has always been the problem on the units I have repaired. Good Luck, Appliance Specialists.
Jan 03, 2010 | Ovens
Oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Dec 17, 2009 | Frigidaire Ovens
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
The gas oven will not light. gas burners light but oven does not
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
O-defective thermostat
O-defective selector switch
O-defective gas safety valve
O-defective gas valve coils
Sep 20, 2009 | Ovens
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Oven won't light
you should have an igniter set up in the oven follow the the front of the burner to the end (back) you should see the igniter follow the wires from the igniter to the elec- safety valve unplug those two wires and tape them together make sure stove is unplugged before you start his process. now plug in oven does igniter light if yes safety valve is bad if no unplug oven from outlet unwrap tapped wires and reinstall them where they came from it would help if you had a ohm meter cut th wires coming out of the igniter not too short in case you have to reconnect them but you will need ceramic wire nuts the do not melt after you cut the wires from the igniter check for continuity @ the igniter no continuity means bad igniter ,i doubt the thermostat is bad but we can troubleshoot it tommorrow if these steps dont work
Jan 03, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
136 people viewed this question
Top Magic Chef Ovens Experts
Sal De
Oloyede Monsuru
reliableservice
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
