Sony VAIO PCG-8X2L will not boot. it loads the VAIO logo and sticks right there. no bios no post.
    Scholar:
  • 97 Answers
You have a currupt bios firmware. You need to pull out your battery, and disconnect the Cmos battery. Next leave it for at least 24 hr. to make certain you clear Cmos. Now get the latest bios update and have it ready to install. Make certain your a/c power supply is attached during this process. Put in a bootable cd with the firmware on it and see if it loads the new Bios firmware. You can then try to boot the Laptop or PC. I have had good luck doing it this way on most laptop's. Good Luck Phil
I have seen some cases where it is a motherboard problem, but not very often. I have also seen where it is caused by defective memory. You may want to test your memory in another laptop or borrow a chip to see what happens.
P.S. Here is the link to your bios firmware.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGTR3AP1
Posted on Dec 10, 2009
  • 478 Answers
Hit tab during startup see whats going on it could be that the hard drive failed
When i turn my vaio model pcg-8x2l on the screen doesn't come up but lights do
You need to get it to a hardware store that does repairs. That there is the connection cable from the laptop part to the monitor part being either loose or broken.
Feb 20, 2015 | Computers & Internet
Can you boot from usb on a sony vaio pcg-9s1l
You may need to "Flash" (Update) the Bios. To do this, go online and download the latest Bios update for your machine.
Unzip the downloaded file and place it on an empty Memory stick.
Insert the memory stick and restart your machine. The Bios update should install.
Wait for the process to finish and then see if you now have the option in Bios>Boot Options to Boot from USB.
May 14, 2014 | Sony VAIO Notebook
Format hard dirve
you would either format or delete all of the data from this drive if it has an operating system on it you would format it
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps you
Oct 12, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
Hello, I am contacting you on behalf of my cousin whose computer crashed. She has a system restore disk and I instructed her to reset the order of start up in the BIOS by moving the CD/DVD drive to the...
One of the function keys should get you into the boot menu, F9-F12, to manually select the CD/DVD drive. Pressing Esc or Tab on VAIO logo may display the right information to show which key to press.
Have you tried booting a standard Windows setup disc and checked if the hard disk is working ok?
Aug 24, 2011 | Sony VAIO PCG-K33P Notebook
Hello, I have a Sony Vaio VGC-V3M and I have just a black screen after starting it. I can hear windows loading, and I get the vaio logo, then the Windows XP logo but then blackness. I can get the Bios...
If you can see the windows logo and get into the bios then it is not the graphics card.
Most likely cause is the os itself, just after post press F8 repeatetly until you have the boot mode page open and choose safe mode, in safe mode do a system restore, goto start bar, programs, accessories, system tools and system restore, and start from a resent restore point. This can can take a while, so be patient and let the computer restore itself until you have the windows screen up.
If the restore dosent work, goto safe mode again, right click on my computer goto properties and enter device manager, in there under display adapters click on the plus sign and uninstall the graphics card, reboot. hope this helps post back if need farther help.
Feb 15, 2010 | Sony VAIO VGC-RB38G PC Desktop
I am trying to install new RAM on my mother's Sony VAIO PCG-K25 laptop. It had two slots, each with 256MB sticks in them. I replaced these with 512MB sticks, and the computer wouldn't boot. It wouldn't...
make sure they are compatible with your computer, there are alot of electronic stores (circuit city) was the worst at it, but will sell you the wrong ones and say they are backwards compatible.. usually P4 2.8 can run PC2700, some run PC2100, which im hoping yours is PC2700... if so, make sure they are NON-ECC also... i would just get 2 1 gig PC2700 DDR 200pin sticks and stick em in... good luck
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Sony Vaio PCG-6L7P unable to boot. Unable to load
HARDWARE PROBLEM, TRY TO RESET THE BIOS OR REMOVE THE REMOVABLE DISK CD/DVD ROOM, THEN USE EXTERNAL
Jun 26, 2009 | Sony Computers & Internet
Computers & Internet Logo
1,059 people viewed this question
Alun Cox
David Payne
David Payne
