Question about Astar LTV-3201 32 in. LCD Television
I need This part:
I took my tv to repair, and they need This part:
With this printed on the top:
ALi
M6759 A1
0440 TW34
IN2L4516000F
Where can I buy it in México?
  • 616 Answers
Buy in the US ship to you, shopjimmy.com
Posted on Dec 10, 2009
SOURCE:
WHY my accer monitor comes up shows "accer" and then goes blank power off and comes
Hi Ali,
Sounds like the familiar leaking capacitor syndrome.
You will need to remove the back from your monitor which can be a challenge in itself.
Have a look at the power supply board which is the board that the mains cable plugs into.
You should find that some of the capacitors have a bulged appearance on the top or a gooey substance has leaked out onto the board.
Capacitors are the small metal cans on the circuit board.
These need to be replaced and if you are reasonably proficient with a soldering iron this should not prove too difficult.
Try eBay or somewhere similar to locate replacements which are not expensive. Make sure you buy capacitors which are described as low esr. If there are more capacitors of the same value on the board then it would be wise to replace them all.
You should be rewarded with a fully working monitor once again.
I have repaired many monitors with this problem and this has always been due to these leaking capacitors.
Wishing you every success Ali.
May 15, 2014 | Acer AL1916W 19" LCD Monitor
The repair shop I took my HP Photsmart 3200 All-in-One to told me the print heads had been destroyed by using refilled ink cartridges from Office Max and that the print heads were NOT replaceable, that I...
The print heads are not replaceable unless you know what you're doing. Even if you did know what you're doing, you need another bad printer of that series to exchange the print heads. It is easier to just buy a new printer that uses the same 02 ink you're used to, especially if you have a CISS system.
Oct 05, 2010 | HP Photosmart 3210 Printer
We have just had to replace an integrated fridge with freezer compartment with a freestanding one. It sits under an integrated electric hob. There was some stuff on top of the removed integrated item to...
try a sheet of aluminium foil/rockwool/ali foil/rockwool/ali foil (3 layers of ali)max 3"thick slightly compressed.that will do the trick and cheap.....(or fibreglass if rockwool not available)
May 10, 2010 | Refrigerators
I have just purchased a Jensen Digital Audio Player 2 GB model #smp-2gbl and need a manual that the print is large enough that I can read it. Can you help me?
There's a manual for the SMP-xGBL model going to next link:
http://www.spectraintl.com/jn/pdf/SMP-2GBL%20English%20UM%20(ALI,%20no%20DRM,USA).pdf
Adobe Reader is needed to read this manual in pdf format.
Enlarge the view to about 200% or choose fill to width of screen in the top bar of Adobe Reader to enlarge fonts and pics. ( zoom - function )
For a large print of the pdf file choose
above the top bar of Adobe Reader:
File > Print...
in the print overview under Page Handling:
Page Scaling [ Tile all pages ]
Tile Scale [ 200 % ]
Hope this was enough information to get a readable manual.
When needing more help, just post a comment.
Jan 15, 2010 | Jensen Audio Players & Recorders
Processor short-circuit.
I just crossed referenced that part, and the sofware couldn't find it. You need to find out what manucturer it is, then go to that web site and order it. How many pins does it have? Is it a sip, or a dip chip? sip stands up with pins at the bottom., dip lays flat with pins on both sides. You may have to order that from the product manufcturer.
Jul 01, 2009 | NAD T752 Receiver
Small picture with lines
check these two resister also R19702= 750k, R19703= 750k
Dec 20, 2007 | RCA P46921 46" Rear Projection Television
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
No power with remote or manual power switch
Your convergence module is probably bad. It is a plug in module, so labor would be lower if the convergence settings are still good. The bill would be about $300.00 If not, the labor for convergence would add to the bill. If the whole job needed full convergence the cost would be about $500 to $600. Hope this helps, Lee http://www.CrazyComputers.com
Jun 22, 2007 | RCA P60921 60" Rear Projection Television
Astar LTV-3201 32 in. LCD Television Logo
101 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
