Question about Sony STR-DH500 A/V Receiver
No sound from Sony STR-DH500 when playing dvds with HDMI
No sound from Sony STR-DH500 when playing dvds in blu-ray player ... connected with HDMI cables, sound goes to tv but i want sound to come out AVR speakers??? need help
No sound via hdmi cables, you must use optical or coaxial
Posted on Dec 18, 2009
My blu ray 3d dvd player will not show picture on blu ray discs only sound but will play regular dvds correctly
The video for blu ray disks come out of the HDMI port and that has to be connected to the TV for video. If it is connected, make sure the TV is switched to the correct HDMI port on the TV (assuming you have a flat screen HDTV).
May 11, 2014 | Vizio Televison & Video
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
No sound through yamaha htr-5750 receiver and samsung blu-ray
That's because tha hdmi is desing to play sound to the reciver you may have to use out put sound from the unit.
Dec 06, 2013 | Sony STR-DG510 Receiver
How do I play DVD on the BlueRay player?
According to the Vizio website, your VBR231 CAN play DVDs the same way a lot of Blu-Ray players can. The site blurb suggests the VBR231 is backwards compatible - which means your player should be able to play DVDs as well as Blu-Ray. Generally, most Blu-ray players can play DVDs if they are backwards compatible with them.
I do know Blu-Ray discs will NOT work in most standalone DVD decks.
MODEL NUMBER: VBR231
*Model Features:
* Full HD 1080p Video Playback
* Integrated Dual Band Wi-Fi - 802.11n
* 7.1 Digital Audio Output
* Backwards Compatible (see below)
*Compatibility:
* Plays Blu-ray and DVDs, Audio CDs, MP3s and Jpegs
* Multi-Channel 7.1 Audio Output via HDMI
* Playback and Enjoy Media via back USB Input (JPEGs and MP3s)
*Outputs:
* HDMI 1.3
* Component Video (YCrCB)
* Composite Video
* Stereo Audio
* Coaxial Audio
* Optical Digital Audio
I hope that helps somewhat.
Feb 02, 2011 | Vizio VBR231 Blu-Ray Player
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Amp/Receiver Setup For Multiple Gadgets!!
Yes - PS3 with a HDMI cable for picture, Fiber Optic for sound, Wii use either component or composite cables, and PC use the left and right jacks.
Sep 18, 2009 | Sony STR-DH500 A/V Receiver
Distorted audio on my surround sound
If it does it with just the one disc it is probably the file that you burned. Does the file sound ok on the computer? Sometimes files that are downloaded have bad audio tracks and I have seen cases where the encoding software that you are using messes up the file when it is modifying the file.
Try another DVD or Blu-Ray disc and see if it still distorts. If it does then it may be a setting in the player or in the receiver.
Cheers
Jan 01, 2009 | Sharp BDHP20U Blu-Ray Player
NO SURROUND SOUND WHEN PLAYING BLU-RAY
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
Sony STR-DH500 A/V Receiver Logo
1,412 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
